电子发烧友论坛|
我从安捷伦站点下载了一个C#程序示例,并且存在一个运行时问题,产生以下输出:未处理的异常:System.Runtime.InteropServices.COMException(0x80040154):检索具有CLSID的组件的COM类工厂{02FDCBA6-7437
-4A46-8F58-9A33E7FBE63C}由于以下错误而失败:80040154.在C: Program Files Agilent 34980 Examples CSharp IVI-COM Multifunction Multifunction.cs中的Multifunction.Main(String [] args) :第55行按任意键继续。 。 我想我已经安装了所有IVI-C和IVI-COM和VISA驱动程序,但我不明白为什么会出现这个“dll not registered error”。我正在使用Visual Studio 2010并尝试执行IVI COM: 34950A和C#.NET用户生成的跟踪示例程序。 操作系统是Win7(请不要告诉我不支持Win7)在此先感谢任何回复.Eric 以上来自于谷歌翻译 以下为原文 I downloaded a C# program sample from the Agilent site and there is a run time problem that produces the follwing output: Unhandled Exception: System.Runtime.InteropServices.COMException (0x80040154): R etrieving the COM class factory for component with CLSID {02FDCBA6-7437-4A46-8F5 8-9A33E7FBE63C} failed due to the following error: 80040154. at Multifunction.Main(String[] args) in C:Program FilesAgilent34980Exampl esCSharpIVI-COMMultifunctionMultifunction.cs:line 55 Press any key to continue . . . I think I have all of the IVI-C and IVI-COM and VISA drivers installed but I don't understand why this "dll not registered error" appears. I'm using Visual Studio 2010 and trying to execute the IVI COM: 34950A and C#.NET User Generated Trace Example program. The OS is Win7( please, please don't tell me that Win7 is not supported) Thanks in advance for any replies. Eric |
1个回答
修复64位系统上损坏的编程示例:问题:尚未转换为64位操作的驱动程序的IVI驱动程序示例将无法重新编译并正确运行。
使用我们的仪器在Web上发布的许多其他IVI驱动程序编程示例也存在此问题。问题是最初这些程序是在32位系统上开发的,默认的构建配置设置是“任何CPU” 。有关如何修复的更多信息和说明,请参阅附件。固定64位Systems.pdf的示例 以上来自于谷歌翻译 以下为原文 Fixing Broken Programming Examples on 64-bit Systems: Problem: IVI driver examples for drivers that have not yet been converted to 64-bit operation will not re-compile and run correctly. This problem would also exist for many of our additional IVI driver programming examples that are posted on the Web with our instruments. The problem is that initially these programs were developed on 32-bit systems, and the default build configuration setting was “ANY CPU”. See attached for more information and instructions on how to fix.Fixing Examples for 64-bit Systems.pdf 附件 |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:28 , Processed in 0.721278 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2985
