电子发烧友论坛|
嗨,我想在SPARTAN 3E板上下载我的VHDL代码,利用J28 JTAG头,但是无法做到。我想知道是否有任何电缆以这种方式下载或者是否有人这样做并且可以帮助我
。=)谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I want download my VHDL code on a SPARTAN 3E board, utilising the J28 JTAG header, but couldn't do it. I want know if there are any cable to download in this way or if anyone has done this and can help me. =) Thanks. |
7个回答
如果你包括:
- 你有什么Spartan-3E板(制造商和电路板) - 那里有许多不同的电路板 - 你尝试过什么 但最常见的S3E板很可能是Xilinx / Digilent Spartan-3E入门套件,恰好有J28作为备用JTAG接头,所以我假设你的意思是...... http://www.xilinx.com/products/devkits/HW-SPAR3E-SK-US-G.htm 该板已经相当于板上嵌入的平台USB线。 因此,除非您的计算机没有USB端口或嵌入式电缆等效设备已损坏,否则使用备用JTAG标头确实没有意义。 但是如果你想这样做,你需要一根JTAG电缆,例如 HW-PC4,HW-USB(不再制造)或HW-USB2: http://www.xilinx.com/onlinestore/program_solutions.htm 该主板的用户指南(ug230)包含有关通过USB端口下载编程文件的部分。 BT 以上来自于谷歌翻译 以下为原文 It would probably help if you included: -what Spartan-3E board (manufacturer and board) you have - there are many different boards out there -what you've tried But the most common S3E board is likely the Xilinx/Digilent Spartan-3E Starter Kit, which just happens to have J28 as the alternate JTAG header, so I'm assuming you mean this... http://www.xilinx.com/products/devkits/HW-SPAR3E-SK-US-G.htm This board already has the equivalent of a Platform USB cable embedded on the board. So there is really no point in using the alternative JTAG header unless your computer doesn't have a USB port or the embedded cable equivalent appears damaged. But if you wanted to do this, you would need a JTAG cable, e.g. HW-PC4, HW-USB (no longer made), or HW-USB2: http://www.xilinx.com/onlinestore/program_solutions.htm This board's user guide (ug230) includes a section on downloading your programming file via the USB port. bt
我之前见过那个电缆,但从未使用过它。
我知道,直到最近(12.1),有必要使用Digilent自己的ADEPT软件下载编程文件。 支持JTAG电缆的Xilinx软件(例如iMPACT,Chipscope,xmd,playsxvf等)支持Xilinx PC4和Platform USB / USB II电缆。 我相信12.1增加了Chipscope对Digilent& amp ;;的支持。 ByteTools电缆。 Digilent很可能知道。 但是您引用的页面仍然暗示您必须使用它们的实用程序。 这对您来说可能重要,也可能不重要。 我个人喜欢使用支持的电缆。 BT 以上来自于谷歌翻译 以下为原文 I've seen that cable before but have never used it. I do know that until possibly recently (12.1) it was necessary to use Digilent's own ADEPT software to download the programming file. The Xilinx software which supports JTAG cables (e.g. iMPACT, Chipscope, xmd, playsxvf, et.) supports the Xilinx PC4 and Platform USB/USB II cables. I believe 12.1 added Chipscope support for the Digilent & ByteTools cable. Digilent would likely know. But the page you referenced still implies you have to use their utility. This may or may not be important for you. Personally I like to use a supported cable. bt
那么,是否不可能使用SPARTAN 3E的J28 JTAG链来下载该FPGA中的程序?
以上来自于谷歌翻译 以下为原文 So, is it not possible use the J28 JTAG chain of the SPARTAN 3E to download a program in this FPGA? |
可以通过Xilinx USB平台电缆对评估板进行编程(J28)。
这条电缆目前的售价约为225美元。 与所有USB外围设备一样,平台电缆必须由Xilinx提供的USB设备驱动程序支持。 Xilinx SW工具(Impact,ChipScope等)支持Xilinx USB平台电缆的Xilinx USB设备驱动程序。 您还有一些替代选择: 1.评估板上的电路完全等同于Xilinx USB平台电缆。 您可以使用简单的USB电缆连接到此。 由于该电路模拟Xilinx平台电缆,因此它使用相同的USB设备驱动程序,并且相同的Xilinx SW工具支持板载电路。 如果您还没有平台电缆,这可以为您节省很多钱。 2.您可以购买Xilinx USB平台电缆的第三方“克隆”,价格约为75- 150美元。 因为它们是反向工程克隆,所以它们与Xilinx提供的USB驱动程序和SW工具配合使用。 3.您可以购买第三方下载电缆,它不是Xilinx平台电缆的克隆版。 由于它的行为与Xilinx平台电缆不同,因此需要使用不同的USB设备驱动程序,该驱动程序必须由下载电缆的制造商提供。 Xilinx SW工具可识别Xilinx USB设备驱动程序。 他们还会识别任何旨在模仿Xilinx USB设备驱动程序的设备驱动程序。 由于Digilent USB驱动程序不能模拟Xilinx USB设备驱动程序,并且由于Xilinx SW工具不支持Digilent设备驱动程序,因此您必须获得支持Digilent(例如Adept)的Digilent硬件和驱动程序的SW工具。 所有这一切的重点是描述硬件,连接器,驱动程序和支持软件的正确关系。 从TIMPE写的内容来看,Xilinx可能会对Xillinx SW工具的最新版本添加对Digilent硬件和驱动程序的支持。 如果是这样,那么你有额外的选择: 3.a使用Digilent USB下载电缆,安装相应的USB设备驱动程序(可能来自Digilent),并更新到支持Digilent HW +驱动程序的最新版本的Xillinx SW。 希望这能为您提供足够的信息。 听起来你有很多选择可以满足你的需求。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 The eval board can be programmed (J28) via a Xilinx USB Platform Cable. This cable currently sells for around $225 US. Like all USB peripherals, the Platform Cable must be supported with a USB device driver, which is supplied by Xilinx. The Xilinx SW tools (Impact, ChipScope, etc.) support the Xilinx USB device driver for the Xilinx USB Platform Cable. You also have some alternative options: 1. On the eval board is circuitry entirely equivalent to the Xilinx USB Platform Cable. You connect to this with a simple USB cable. Since this circuitry emulates the Xilinx Platform Cable, it uses the same USB device driver, and the same Xilinx SW tools support the onboard circuitry. This saves you quite a bit of money, if you don't already have a Platform Cable. 2. You can purchase a 3rd party 'clone' of the Xilinx USB Platform Cable, for around $75-$150. Because they are reverse-engineered clones, they work with the Xilinx-supplied USB driver and SW tools. 3. You can purchase a 3rd party download cable which is NOT a clone of the Xilinx Platform Cable. Because it behaves differently than the Xilinx Platform Cable, it requires a different USB device driver, which must be supplied by the manufacturer of the download cable. The Xilinx SW tools recognise the Xilinx USB device driver. They would also recognise any device driver designed to mimic the Xilinx USB device driver. Because the Digilent USB driver does NOT mimic the Xilinx USB device driver, and because the Xilinx SW tools do not support the Digilent device driver, you must get SW tools which support the Digilent hardware and driver from Digilent (e.g. Adept). The point of all this is to describe the proper relationship of hardware, connectors, drivers, and support software. From what TIMPE wrote, it may well be that Xilinx has added support for Digilent hardware and driver to the latest revisions of Xillinx SW tools. If so, then you have the additional option: 3.a Use the Digilent USB download cable, install the appropriate USB device driver (probably from Digilent), and update to a recent version of Xillinx SW which supports the Digilent HW + driver. Hopefully this gives you enough information going forward. It sounds like you have a number of options which will meet your needs. - Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
好吧,鲍勃。
虽然JTAG本身是一个标准(例如IEEE 1149.1-2001),但有一些关于特定电缆(及其SW接口),设备驱动程序和应用程序支持的细节可能最初并不明显......;) BT 以上来自于谷歌翻译 以下为原文 Well put, Bob. Although JTAG itself is a standard (e.g. IEEE 1149.1-2001), there are some details with respect to particular cables (and their SW interface), device drivers, and application support that may not be initially obvious... ;) bt
为了解决这个问题,Digilent XUP USB-JTAG电缆不需要第三部分安装或Adept编程,但直接使用Xilinx iMPACT软件。
它还支持Chipscope,EDK等。它几乎是Xilinx平台电缆。 RegardsPeter BoxallManaging DirectorBlack Box ConsultingXilinx授权培训ProviderLive在线讲师带领全球培训 以上来自于谷歌翻译 以下为原文 Just to clear this up, the Digilent XUP USB-JTAG cable does not require 3rd part installs or Adept to program, but directly uses the Xilinx iMPACT software. It also supports Chipscope, EDK etc. Its pretty much the Xilinx Platform cable. Regards Peter Boxall Managing Director Black Box Consulting Xilinx Authorised Training Provider Live Online Instructor Led Training World-Wide |
Digilent提供多种不同的USB电缆。
其中,其中三个(如本文所述)标记为USB JTAG电缆。 其中一个与Xilinx USB平台电缆和Xilinx Impact工具插件兼容。 其他两个被描述为与Digilent Adept SW工具兼容。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Digilent offers a number of different USB cables. Of these, three of them (as this is written) are labeled as USB JTAG cables. One of them is plug-compatible with the Xilinx USB Platform Cable and Xilinx Impact tools. The other two are described as compatible with Digilent Adept SW tools. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 23:44 , Processed in 0.831177 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1217
