电子发烧友论坛|
我发送了正确的帧信号(带有软件)到极光,但我无法在极光的接收器上得到软信号(eof和src信号正确)。
我该怎么办? 要删除数据? 以上来自于谷歌翻译 以下为原文 I sent the right frame signal (with the sof eof) to the aurora,but I can't get the sof signal (the eof and src signal right)on the receiver of aurora sometime. what should I do? To drop the data? |
3个回答
核心配置是什么?
发布.xco文件供参考。你是否在simulation.Regards,Krishna上看到了这个问题 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 What is the core configuration? Post .xco file for reference. Are you seeing this issue on simulation. Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
你发送了多少帧?
如果您发送多个帧并且没有为它们显示SOF,我希望得到frame_err断言。 是这样的吗? -------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 How many frames are you sending? If you are sending more than one frame and SOF does not appear for them, I expect to get frame_err asserted. Is this the case?------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------ |
确认您遵循协议要求以在模拟中传输帧。
-------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Confirm that you are following the protocol requirements to transfer the frames in simulation.------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------ |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 16:14 , Processed in 0.929956 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9686
