我正在尝试使用一个I2S输入并发送L / R立体声作为标准的D类PWM,并在线路电平输出低音炮。通过正确设置交叉以及如何使用DDX耳机输出来创建线路电平信号,我的困惑就出现了。您建议使用什么配置来实现此目的?有没有办法在这种配置中切换两个不同的I2S输入,如A / B选择器?
#audio-processing#sta309a 以上来自于谷歌翻译 以下为原文 I am trying to use one I2S input and send out L/R stereo as standard class-D PWMs and output the subwoofer at line level. My confusion arises with properly setting up the cross-over and how to use the DDX Headphone output to create a line level signal. What configuration would you recommend to achieve this? Is there a way to switch between two different I2S inputs like a A/B selector in this configuration? #audio-processing #sta309a |
2个回答
我对这个话题也很感兴趣。我希望连接STA311B的耳机输出,我假设它与STA309A电路非常相似。
在两个数据表中都提到了连接,但没有提供示例原理图。 你能分享一个示例原理图吗? 以上来自于谷歌翻译 以下为原文 I'm also very interested in this topic. I wish to connect the headphone output of a STA311B, which I'm assuming would be very similar to the STA309A circuit. In both datasheets the connection is mentioned, but in none a sample schematic is provided. Can you share a sample schematic? |
你好Loebold,
对于STA309A或STA311B,侧面有8个处理通道,您可以将任何输入映射到任何处理通道或将它们混合在一起。 然后,对于您的应用,您可以将通道1和2用作I2S输入通道,并将它们映射到3和4通道。 之后,您可以将通道1和2的PWM输出应用于立体声D类输出,混合通道3和4输出togethr(每通道-6dB),还在通道3或4输出中添加1或2个低通滤波器,最后你可以从通道3或4获得低音扬声器输出。 由于可以使用单独的通道控制,因此您只需使用通道静音来控制它们的输出电平。 谢谢 , YT 以上来自于谷歌翻译 以下为原文 hi Loebold , for STA309A or STA311B , there are 8 processing channels in side , and you are able to map any input to any processing channel or mix them together . then for your applicaiton , you can use channel 1 and 2 as I2S input channel , and map them to 3 and 4 channel . after that , you can apply PWM output from channel 1 and 2 for stereo class D output , and mixed channel 3 and 4 output togethr ( -6dB each channel ) , also added 1 or 2 low pass filter in channel3 or 4 output , finally you can get woofer output from channel 3 or 4 . since individual channel control are available , so you just need to use channel mute to control output level of them . thanks , YT |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2644 浏览 1 评论
3209 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1784 浏览 1 评论
3613 浏览 6 评论
5990 浏览 21 评论
940浏览 4评论
1317浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
585浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1304浏览 3评论
1362浏览 3评论
GMT+8, 2024-11-26 00:27 , Processed in 1.237315 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
