嗨,
我正在尝试构建和使用这个设计:https://hackaday.io/project/364原型,但我发现的问题是,这是使用DDR内存MT46V32M16P-5B:F我无法在任何地方找到它 (至于我可以研究,它已停止)任何人都可以确认我这个? 社区还在使用像这样的DDR内存吗? 无论如何,对于内存模型的用户指南(www.xilinx.com/cn/support/documentation/user_guides/ug388.pdf),我只能找到DDR3内存类型来替换它最高可达1GB。 我在这个PCB和电路设计方面真的很新,所以我想知道是否有人能告诉我: 1)什么样的插座更适合这种设计?60-FBGA / 60-TFBGA / 92-FBGA 2)我需要重写内存管理代码吗? 因为斯巴达-6没有。 在此事先感谢帮助新的发烧友:D 以上来自于谷歌翻译 以下为原文 Hi, i'm trying to build and use this design: https://hackaday.io/project/364 for a prototype, but the problem i found, is that is using a DDR memory MT46V32M16P-5B:F and i could not find it anywhere (and as far i could research, it is discontinued) anyone can confirm me this? the community is still using DDR memories like this? anyway for the user guide of memory models ( www.xilinx.com/support/documentation/user_guides/ug388.pdf ) i could only find DDR3 memory types to replace it available to up to 1GB. i'm really new in this matter of PCB and circuit design, so i was wondering if anyone could tell me: 1) what kind of socket is better for this design? 60-FBGA / 60-TFBGA / 92-FBGA 2) i would need to rewrite the memory management code right? as the spartan-6 doesn't have one. Thanks in advance for helping a new enthusiast in this matter :D |
2个回答
嗨,
我认为该部件是可用的,请在下面链接查看数据表和购买选项 http://www.micron.com/parts/dram/ddr-sdram/mt46v32m16p-5b 有关适当信息,请参阅Micron网站上的产品过时信息 Spartan 6具有可用于连接内存的MIG / MPMC IP,请详细说明内存管理的含义 从MIG明智地,您可以使用自定义零件实用程序生成其等效零件,有关详细信息,请通过MIG IP向导自定义零件帮助菜单 FBGA / 60-TFBGA / 92-FBGA的选择取决于您的电路板设计要求,如空间,芯片成本,优势和各种封装的不利因素 问候, Vanitha -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, I think the part is availabe, please check below link for datasheet and buying options http://www.micron.com/parts/dram/ddr-sdram/mt46v32m16p-5b For product obsolescence info post in Micron site for appropriate information Spartan 6 has MIG/MPMC IP that can be used for interfacing memory, please elaborate what you mean by memory management From MIG wise you can generate its equivalent part using custom part utility, go through MIG IP wizard custom part help menu for details Choice of FBGA / 60-TFBGA / 92-FBGA depends on your board design requirements like space, chip cost, advanatages and disadvanatges of various packages Regards, Vanitha --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
仅供参考,部分末尾的F是模具修订版。
美光定期更新这些,最新的部件版本是rev:J而不是:F。 Micron的模具转速并不意味着任何功能上的改变,而且我从来没有遇到过在现有电路板上使用相同底层部件的较新芯片转速的问题。 因此,除非您担心版本控制,否则您应该忽略冒号后的Micron部件号。 - Gabor 以上来自于谷歌翻译 以下为原文 Just FYI, the :F at the end of the part is the die revision. Micron regularly updates these, and the latest part version is rev :J rather than :F. Micron's die rev's do not imply any functional change, and I've never had an issue using newer die rev's of the same underlying part in an existing board. So unless you are worried about revision control, you should probably ignore the part of the Micron part number after the colon. -- Gabor |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
652浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
461浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
668浏览 0评论
1860浏览 0评论
GMT+8, 2024-9-29 07:03 , Processed in 1.333969 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
