我试图读回TDA7419音频处理器上的I2C寄存器以验证其内容。我尝试了标准I2C寄存器读取以及数据表(rev7)第29页上的自定义方法。在所有情况下,都接收到NACK并且不发送数据。
注册回读是否适用于TDA7419。如果是这样,有人有明确的时序图吗? 谢谢! #audio-processing#i2c#tda7419 以上来自于谷歌翻译 以下为原文 I am trying to read back I2C registers on the TDA7419 audio processor to verify their contents. I've try both standard I2C register reads as well as the custom method on Page 29 of the datasheet (rev7). In all cases, a NACK is received and no data is transmitted. Does register read-back work on the TDA7419. If so, does anyone have an explicit timing diagram? Thanks! #audio-processing #i2c #tda7419 |
1个回答
我是支持这一系列设备的ST技术人员之一。
我为答案的延迟道歉,但现在才引起我的注意。 无法回读TDA7419的“写入”寄存器:它们只能写入。 大多数客户到目前为止所做的是定期更新TDA7419(以及我们的汽车无线电CSP产品组合中的所有其他音频处理器)的寄存器(例如每分钟左右),以防万一需要确保编程值不会因不可预见的情况而破坏,并妨碍汽车收音机的正常运行。 以上来自于谷歌翻译 以下为原文 I am one of the ST technical staff supporting this line of devices. I apologize for the delay in the answer, but it has been brought to my attention only now. It is not possible to read back the 'write' registers of the TDA7419: they are write only. What most customers have been doing up to now is to refresh the registers of the TDA7419 (and of all the other audio processors in our car-radio CSP portfolio) regularly (e.g. every minute or so), in case one wanted to make sure that the programmed values would not be corrupted by unforeseen circumstances and prevented the normal operation of the car radio. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2496 浏览 1 评论
3170 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1736 浏览 1 评论
3559 浏览 6 评论
5934 浏览 21 评论
897浏览 4评论
1272浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
539浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1258浏览 3评论
1312浏览 3评论
GMT+8, 2024-10-14 09:56 , Processed in 1.298770 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
