我正在使用PSoC3设备(CY8C3244Lti—123)进行项目,并开始内存不足。我在一个应用笔记题为“PSoC3 - 8051代码和内存优化”(an60630),在那里了解了一些内存,我可以通过一定的方式访问类型deffing变。这些变化帮助我利用一些闲置的记忆,给了我一些必要的更新我的项目编码更多的空间。这是在创建者2和2.1。我已经升级到3,不是我的造物主警告我,我的the'bit编译类型定义一个1位的变量。据an60630这是可行的,当使用造物主2和2.1它工作的很好。有什么想法为什么我警告我自从升级到版本3.0?
警告:“类型说明符失踪,默认为“int”。 谢谢。。。 以上来自于百度翻译 以下为原文 I am working on a project using a PSoC3 device, (CY8C3244LTI-123), and began runnign out of memory. I came accross an appnote titled, "PSoC3 - 8051 Code and Memory Optimization" (AN60630), where I learned about some internal memory that i could access by type deffing varialbe a certain way. Making these changes helped me utilize some unused memory and gave me more room for coding some necessary updates to my project. That was in Creator 2.0 and 2.1. I have upgraded to Creator 3.0 and not I get an warnings when I compile where I use the 'bit' type def a 1 bit variable. According to AN60630 this is doable and when using creator 2.0 and 2.1 it worked great. Any ideas on why I get the warning I do since upgrading to version 3.0? Warning reads, " type specifier missing, defaults to 'int' ". Thanks... |
5个回答
在PSCOS3的代码编辑器中标记的警告(有时甚至错误)更好地被用作提示。应该注意构建步骤中的警告(和错误)并应避免。
你的警告是从哪里冒出来的? 鲍勃 以上来自于百度翻译 以下为原文 Warnings (sometimes even errors) flagged in the code-editor for a PSoC3 are better taken as a hint only. Warnings (and errors) from the build-step are to be taken seriously and should be avoided. Where do your warnings pop up? Bob |
它显示为一个小的黄色三角形,有一个“!”只在灰色阴影栏的行号左边标记。
以上来自于百度翻译 以下为原文 It shows as a small yellow triangle with an " ! " mark in it just to the left of the line number in the grey shaded column. |
是的,这通常是错误的警告,将与下一版本进行更改。坚持构建报告。
鲍勃 以上来自于百度翻译 以下为原文 Yes, this are often errorneous warnings, will be changed with next version. Stick to the build-report. Bob |
谢谢。这很好。我会看到它消失在下一个创建者修订。
这也带来了另一个问题。如果我需要在另一个帖子中重新发布它,那就让我知道。这是关于一个警告但这是我的“通知单”选项卡,(见截图如下)。它是我一个中断时钟容差问题一个UART块。我瞄准的是38400比特/秒的速率。我怎么能容忍与我同步定时需要作出改变,会影响我的应用程序的其他部分呢? 谢谢。 以上来自于百度翻译 以下为原文 Thanks. That is good to know. I will look to see it go away in the next creator revision. This also brings up another question I have. If i need to repost it in another thread then let me know. It is also regarding a warning but this one is in my "Notice List" tab, (see screen shot below). It reads I have an interrupt clock tolerance issue with a uart block. I'm targeting a rate of 38400 bits/second. How can i get the tolerance in sync wtih my timing needs with making changes that will affect other parts of my application? Thanks. |
一般来说,这个错误意味着时钟链中的某些东西不满足。
设计设置或标准。 项目档案和论坛可以帮助你- “文件”创建者 “创建工作区束” 使用Internet Explorer或Firefox发布,Chrome似乎不起作用。 问候,Dana。 以上来自于百度翻译 以下为原文 This error, in general, means something in the clock chain does not meet design settings or criteria. Post a project archive and forum can assist you - "File" Creator "Create Workspace Bundle" Use Internet Explorer or Firefox to post, Chrome does not seem to work. Regards, Dana. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 18:56 , Processed in 0.590630 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1972
