电子发烧友论坛|
大家好,
我正在尝试使用由STARTUP_SPARTAN6实体生成的EOS信号来实现描述其中的解决方案。 我将FPGA配置为串行从机模式。 在我的设计中实例化STARTUP_SPARTAN6看起来像这样: startup_spartan6_1:startup_spartan6端口映射(EOS => eos, - 在配置完成时启用所有时钟CLK =>'0',GSR =>'0',KEYCLEARB =>'0',GTS =>'0', CFGMCLK => open,CFGCLK => open); 以上编译没有问题。 在行为模拟中(我使用的是ISim 13.4 nt64)我希望看到EOS信号变高,但它会永远处于未定义状态(VHDL'U'状态)。 如何使EOS信号正常运行? 最好的祝福, 亚当 以上来自于谷歌翻译 以下为原文 Hi all, I am trying to use EOS signal generated by STARTUP_SPARTAN6 entity to implement solution descrived in this answer record. I configure my FPGA in serial slave mode. The instantiation of STARTUP_SPARTAN6 in my desing looks like that: startup_spartan6_1 : startup_spartan6 port map ( EOS => eos, -- enabling all the clocks when the configuration is finished CLK => '0', GSR => '0', KEYCLEARB => '0', GTS => '0', CFGMCLK => open, CFGCLK => open); Above compiles without problems. In behavioral simulation (I am using ISim 13.4 nt64) I expect to see EOS signal to go high, but instead it stays in undefined state (VHDL 'U' state) forever. How can I make EOS signal to behave correctly? Best regards, Adam |
1个回答
这是一个已知的问题。
已提交更改请求(CR#668043)以解决此问题。此问题已在14.4或最新版本的工具中得到解决。 请试一试。 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 This is a known issue. A change request (CR#668043) has been filed to fix this. This issue was resolved in 14.4 or latest version of tools. Please give this a try.----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1360浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1198浏览 1评论
/9
GMT+8, 2025-12-14 11:31 , Processed in 1.737303 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2417
