电子发烧友论坛扫一扫,分享给好友
因此,我的“新人”炸了两个旧的功率传感器...公司购买了Agilent N8481A Pwr传感器(1200美元ea),这应该与我们的功率计E4418B配合使用。
我需要将我的固件更新到最新版本才能使用它们,已经升级了DSP板(523美元),所以这就是问题 - 即使E4418B有一个RS-232(我们根本不使用GPIB)连接器 背部; 没有菜单选择可以通过GPIB选择它,即使手册说有。 我不想在GPIB PCI板和电缆上花费更多,只是为了简单的固件更新。 安装的固件是A1.03.00,我需要最新的A1.09.01手册说菜单=系统/输入 - >远程接口 - >选择接口,应该让我在HPIB或Serial之间进行选择。 我的E4418B而不是显示远程接口显示HPIB。 任何想法或帮助将不胜感激 以上来自于谷歌翻译 以下为原文 So my "new guys" fried two of my old power sensors... Company purchased Agilent N8481A Pwr Sensors($1200 ea), which should work with our power meter E4418B. I need to update my firmware to latest version for them to work, already upgraded the DSP board ($523), so here is the problem- Even though the E4418B has an RS-232 (we don't use GPIB at all) connector on back; there is no menu selection to choose it over GPIB, even though the manual says there is. I don't want to spend more on a GPIB PCI board and cable just for a simple firmware update. Firmware installed is A1.03.00 and I need the latest one A1.09.01 The manual says under menus = System/Input -> Remote Interface -> Select Interface, should let me choose between HPIB or Serial. My E4418B instead of displaying Remote Interface shows HPIB. Any ideas or help would be appreciated |
7个回答
为什么有关RF功率计的帖子在电源部分?
射频功率计与交流或直流电源无关。 我之前发布的地方是功率计的帖子应该去的地方。 也许我误会了? 以上来自于谷歌翻译 以下为原文 Why are posts concerning RF power meters in the Power supplies section? A RF power meter has nothing to do with AC or DC power supplies. Where I posted earlier is where power meter posts should go. Maybe I misunderstand? |
我得说,很难与你的逻辑争论......这完全没有任何意义。
你没有误会。 我不知道为什么这会被移到这里。我将要回答你的问题的人现在永远不会找到这个帖子。我会记得提醒他,但这不会是直到星期二。同时试着看看 这些网站:http://www.home.agilent.com/agilent/edi ... id = 1377930http://www.home.agilent.com/agilent/red ... .536881895 以上来自于谷歌翻译 以下为原文 I gotta say, it's hard to argue with your logic...this makes absolutely no sense at all. You did not misunderstand. I am not sure why this was moved here. The guy that I was going to have answer your question will never find this post now. I will try to remember to remind him, but that won't be until Tuesday. Meanwhile try looking at these sites: http://www.home.agilent.com/agilent/edi ... id=1377930 http://www.home.agilent.com/agilent/red ... .536881895 |
如果您检查版本信息[系统] - >(更多) - >(服务) - >(版本),如果功率计认为它是E4418A而不是B,我很好奇。因为您更换了DSP板
很可能在安全/内存清除过程中会重置内存。 由于A模型没有串口,这可以解释为什么没有菜单结构存在。如果是这种情况,则需要使用GPIB使用SCPI命令重新加载信息。 该链接讨论了该过程:http://www.home.agilent.com/agilent/edi ... SR.General 以上来自于谷歌翻译 以下为原文 I'm curious if you check the Version information [System]->(More)->(Service)->(Version), if the power meter thinks it is the E4418A instead of the B. Since you have changed the DSP board more than likely the memory was reset as would happen during the security/memory clearing process. Since the A model did not have a serial port, this would explain why none of the menu structures are present. If this is the case, it is necessary to reload the information using SCPI commands using GPIB. The process is discussed at this link: http://www.home.agilent.com/agilent/edi ... SR.General |
我没有GPIB接口板或电缆,我们不使用它。
我想我要么需要发送它进行固件更新,要么购买GPIB板和电缆。 是否可以使用82357B GPIB到USB适配器进行固件更新? 它会更便宜,更容易使用.-谢谢 以上来自于谷歌翻译 以下为原文 I don't have a GPIB interface board or cable, we don't use it. I guess I either need to send it in for the firmware update or purchase a GPIB board and cable. Is it possible to use the 82357B GPIB to USB adapter to do the firmware update? It would be much cheaper and easier for us to use. -Thanks |
好的,谢谢,看看我是否可以把这个卖给***。
现在... 以上来自于谷歌翻译 以下为原文 Ok thanks, see if I can sell this one to the govt. now... |
顺便说一下,Power Meter现在将型号显示为E4418A ......
以上来自于谷歌翻译 以下为原文 BTW yes the Power Meter shows model number as E4418A now... |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:02 , Processed in 0.916659 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2190
