电子发烧友论坛|
您好,我正在使用E4433B,加载并成功传输波形。
我希望能够像以前使用e4438C一样使用标记,这样我就可以在波形传输完成时将空白消隐。 我所做的是创建并加载到VSG上的波形。 选择标记2并设置点范围以捕获所有波形点。 我将RF空白打开到MKR2,并在标记上显示正极性。 我将触发设置为前面板按钮,单个。 当我按下触发器时,波形会发送,但消隐不起作用。 如果我设置相同的命令序列,但在设置点的范围时,我跳过样本,然后我空白(但我当然不想跳过样本,所以这不符合我的目的)。 我已将固件更新到最新版本B.03.86谢谢,Reese 以上来自于谷歌翻译 以下为原文 Hello, I am using a E4433B, loading and successfully transmitting a waveform. I would like to be able to use the markers as I have done previously using the e4438C so that I can blank the RF when the waveform transmission completes. What I have done is to create and load the waveform on to the VSG. Selected marker 2 and set the range of points to capture all waveform points. I turn RF blank to MKR2 on with positive polarity on the markers. I set triggering to the front panel button, single. When I hit the trigger, the waveform transmits, but blanking does not work. If I set the same sequence of commands, but when setting the range of points, I skip samples, then I blank (but of course I don't want to skip samples, so this doesn't suit my purposes). I've updated the firmware to the latest version B.03.86 Thanks, Reese |
1个回答
嗨Reese,我已经在我的E4437B上进行了相同的固件版本相同的测试,在连续模式下一切正常,但在单发中,如果我使用一系列标记1和2,我没有任何射频
输出。 我尝试了许多组合而没有成功。 出口端口event1和event2的MKR1和MKR2正常。 有人有想法解决这个问题吗? 关心Yves QC,加拿大 以上来自于谷歌翻译 以下为原文 Hi Reese, I've done same test on my E4437B with same firmware revision, in continuous mode everything is OK, but in single shot, if I used a range of points for marker 1 and 2, I didn't have any RF at output. I tried many combination without success. MKR1 and MKR2 at outport ports event1 and event2 was OK. Somebody have an idea to resolve this problem? Regards Yves QC,Canada |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:24 , Processed in 0.476964 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
808
