扫一扫,分享给好友
我需要为防御等级Spartan 6生成一个IBIS文件,用于PCB信号完整性。
我已经安装了最新版本的ISE。 我正在使用30天的eval许可证,直到我获得IT安装的浮动许可证。 我试图生成IBIS模型,我收到一条消息,说ISE不支持这个,我需要从Vivado TCL控制台执行此操作。 此时,我的顶级文件仅包含I / O信号列表。 我确实为所有输入和输出分配了I / O标准。 我不熟悉Vivado,以及TCL和TCL控制台。 任何帮助让我快速启动的帮助将不胜感激。 以上来自于谷歌翻译 以下为原文 I need to generate an IBIS file for a Defense Grade Spartan 6 for PCB signal integrity. I have installed the latest version of ISE. I am working from a 30 day eval license until I get the floating license installed by IT. I attempted to generate the IBIS model and I got a message that said ISE does not support this, and I need to do this from Vivado TCL console. At this point my top level file contains only the I/O signal list. I did assign I/O standards for all inputs and outputs. I am unfamiliar with Vivado, as well as TCL, and the TCL console. Any assistance with this to get me jumpstarted would be appreciated. |
2个回答
嗨,
Vivado仅适用于7系列FPGA,因为您使用的是Spartan-6,请检查以下链接是否对您有所帮助。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/pp_p_process_generate_ibis_model.htm http://www.xilinx.com/support/answers/21632.html 问候, Vanitha -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, Vivado is only for 7 series FPGAs as you are using Spartan-6, please check if below links will help you. http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/pp_p_process_generate_ibis_model.htm http://www.xilinx.com/support/answers/21632.html Regards, Vanitha --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
你好Vanitha,
当我尝试生成ibis文件时,下面的消息是由ISE 14.7生成的。 由于我缺少的东西,我不确定这是否是一个虚假的消息。 我在TCL窗口中运行了“ibiswriter -h”命令,它没有列出防御等级的Spartan 6设备。 问候, 戴夫B. 开始:“生成IBIS模型”。 运行ibiswriter ...... 命令行:ibiswriter -intstyle ise -allmodels -vccaux 3.3 -truncate 20 exctr_a_top.ncd adv_exctr_top.ibs 从环境中的文件'6slx75t.nph'加载应用程序Rf_Device的设备 C:赛灵思 14.7 ISE_DS ISE 。 “exctr_a_top”是NCD,版本3.2,设备xq6slx75t,包cs484,速度 -2 错误:PostProcessors - BISWriter不支持设备qspartan6。 请使用Vivado中TCL控制台的write_ibis。 有关如何的更多信息 要导出IBIS文件,请参阅PlanAhead用户指南 www.xilinx.com/documentaton。 使用ibiswriter -h列出支持的列表 架构。 流程“生成IBIS模型”失败 以上来自于谷歌翻译 以下为原文 Hello Vanitha, The message below was generated by ISE 14.7 when I tried to generate the ibis file. I am not sure if this is a bogus message due to something that I am missing. I did run the "ibiswriter -h" command in the TCL window and it does not list the Defense Grade Spartan 6 device. Regards, Dave B. Started : "Generate IBIS Model". Running ibiswriter... Command Line: ibiswriter -intstyle ise -allmodels -vccaux 3.3 -truncate 20 exctr_a_top.ncd adv_exctr_top.ibs Loading device for application Rf_Device from file '6slx75t.nph' in environment C:Xilinx14.7ISE_DSISE. "exctr_a_top" is an NCD, version 3.2, device xq6slx75t, package cs484, speed -2 ERROR:PostProcessors - BISWriter does not provide support for device qspartan6. Please use write_ibis from the TCL console in Vivado. More information on how to export IBIS files can be found in the PlanAhead User Guide on www.xilinx.com/documentaton. Use ibiswriter -h to list supported architectures. Process "Generate IBIS Model" failed |
只有小组成员才能发言,加入小组>>
2320 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2366 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
652浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
460浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
220浏览 1评论
667浏览 0评论
1859浏览 0评论
GMT+8, 2024-9-28 12:42 , Processed in 1.140863 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
