电子发烧友论坛扫一扫,分享给好友
大家好,
我正试图从microblaze_mcs转移到一个完整的微系统,所以我从EDK生成了一个核心。 我正在使用ISE版本14.5。 我要经历的步骤是: 1.在ISE中打开现有设计。 2.打开XPS,配置合适的核心。 3.将新核心导入ISE(通过add-source从XPS添加xmp文件) 4.综合设计 5.通过单击xmp文件导出到SDK,并“将硬件设计导出到没有比特流的SDK” 6.在SDK中创建板项目,bsp项目和应用项目 7.编写一些代码,编译时没有错误。 8.在ISE内生成编程文件。 一切正常,直到我到达运行Data2MEM的'生成编程文件'的末尾。 错误是: Data2MEM:47 - 并非ADDRESS_SPACE中的所有BitLLanes。 bmm文件看起来不错。 我已经检查了映射日志,MCS和Block-rams肯定在那里。 如果我进一步观察,我会在NgdBuild中收到以下警告: NgdBuild - RAMB16BWER类型的inxtance“.....”上的SIM_DEVICE值已从“SPARTEN3ADSP”更改为“SPARTAN6” 这可能是错误的来源吗? 这似乎是来自XPS项目,所以我完全不知道如何纠正这个! 如果我可以得到verilog文件,有关于如何做到的各种注意事项,例如: http://www.xilinx.com/support/answers/37595.html 但鉴于它是在XPS中生成的,我无法看到如何在任何地方更改此参数。 有任何想法吗? 以上来自于谷歌翻译 以下为原文 Hi All, I'm trying to move from a microblaze_mcs to a microblaze full system, so I've generated a core from the EDK. I'm using version 14.5 of ISE. The steps that I'm going through are: 1. Open Existing design in ISE. 2. Open XPS, and configure a suitable core. 3. Import new core into ISE (via add-source to add the xmp file from XPS) 4. synthesise design 5. Export to SDK by clicking on the xmp file, and "export hardware design to SDK without bitstream" 6. create board project, bsp project, and application project in SDK 7. write some code, and compile with no errors. 8. within ISE Generate programming file. Everything works until I get to the end of the 'generate programming file' where Data2MEM gets run. The error is: Data2MEM:47 - Not all BitlLanes in ADDRESS_SPACE. The bmm file looks ok. I've checked the mapping log, and the MCS and Block-rams are definitely there. If I look further, I get the following warnings in NgdBuild: NgdBuild - The value of SIM_DEVICE on inxtance '.....' of type RAMB16BWER has been changed from 'SPARTEN3ADSP' to 'SPARTAN6' Could this be the source of the errors? This seems to be from within the XPS project, so I've absolutely no idea how to correct this! There are various notes on how to do this if I can get my hands on the verilog files e.g.: http://www.xilinx.com/support/answers/37595.html But given that it's generated from within XPS, I can't see how to change this parameter anywhere. Any ideas? |
2个回答
好的,所以显然有一些遗留在系统隐藏在某个地方的原始microblaze_mcs。
启动一个全新的项目,复制所有设置似乎工作。 我想我唯一可以建议的是,不要尝试更新旧项目 - 只需启动一个新项目! 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 ok, so there are clearly some relics to the original microblaze_mcs hidden in the system somewhere. Starting a completely new project, copying all the settings over seems to work. I guess the only thing that I can suggest, is don't try and update an old project - just start a new one! View solution in original post |
好吧,一个没有其他内容的示例项目似乎工作......所以我猜这个警告是无关紧要的。
而且我正在努力减少事情,看看事情何时开始奏效,但这有点令人沮丧地缓慢。 我已经在planAhead floorplanning视图中验证了RAM是在那里,并且在正确的位置(即匹配BMM层次名称),所以我不知道它为什么不工作。 我已经清除了对microblaze_mcs的所有引用,并删除了所有非关键文件(即我已将所有设计文件复制到一个干净的新区域并从那里开始),但这没有帮助! 任何建议都非常感谢。 以上来自于谷歌翻译 以下为原文 Well, an example project with nothing else in, seems to work... so I'm guessing the warning is irrelevant. And I'm trying to cut things out to see when things start to work, but it's a bit frustratingly slow. I've verified in planAhead floorplanning view that the RAM's are there, and at the correct locations (i.e. match the BMM hierarchical names), so I'm at a loss as to why it's not working. I've cleaned out all references to the microblaze_mcs, and deleted all non-critical files (i.e. I've copied all the design files into a clean new area and started from there), but that's not helping! Any suggestions are greatly appreciated. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 20:23 , Processed in 0.536868 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1519
