电子发烧友论坛|
当使用Spartan-6 FPGA GTP Transveivers时,数据速率为1.25Gbps时,发送器和接收器之间的信道频率有多大的损耗?
以上来自于谷歌翻译 以下为原文 When using Spartan-6 FPGA GTP Transveivers, at a data rate of 1.25Gbps, how lossy in dB can the channel be between the transmitter and receiver? |
3个回答
您是否阅读了用户指南和迈克尔,
奥斯汀 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Have you read through the user's guide and Michael, Austin Austin Lesea Principal Engineer Xilinx San Jose |
我通过高级产品规范和第112页讨论了通道的插入丢失。
但是我无法找到特定频率下的最大信道损耗,即接收方能够处理并仍能接收没有误码的数据。 以上来自于谷歌翻译 以下为原文 I went through the advanced product spec and on page 112 it talks about insertion loss of the channel. but i am unable to find the max channel loss at specific frequencies that the receiver will be able to handle and still receive the data without bit errors. |
150 mV是最小输入差分容量,
根据数据表。 如果输出可调节至1v差分,并且接收器具有增益(如图所示),您可以从那里弄清楚。 我也总是有3dB余量(信号总是至少是计算所需的两倍)。 完成所有操作后,符号率(比特率1/2)的最大损耗约为10dB。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 150 mV is the minimum input differential volrage, Per the data sheet. If the output is adjustable up to 1v differential, and the receiver has gain (as shown), you can go figure it out from there. I would always have a 3dB margin, also (signal is always at least twice what the calculations show is needed). When all is said and done, the max loss is around ~ 10dB at the symbol rate (1/2 the bit rate). Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 17:52 , Processed in 0.639690 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2884
