电子发烧友论坛扫一扫,分享给好友
我使用PIC16F503 MCU和MPLAB X V3.4i AM试图输出一个电压信号来激活MOSFET,当我按下开关时发光二极管,但由于某种原因,我的DAC输出引脚总是很高,当我按我的开关时,代码执行,但只增加了50 mV的输出。我不知道问题是什么。我和DAC一起工作已经有几年了,我不确定如何解决这个问题。非常感谢您的帮助。
以上来自于百度翻译 以下为原文 I am using a PIC16f1503 MCU and mplab X V3.4 I am trying to output a voltage signal to activate a mosfet to light an led when i press a switch, but for some reason my DAC output pin is always high and when i press my switch the code executes but only increases my output by 50 mV. I dont know what the issue is. Its been a few years since I've worked with DAC and am not sure how to fix the issue. any help is greatly appreciated. |
8个回答
水晶球说……如果没有看到任何代码或示意图,这有点困难。这不是真正的MPLABX IDE问题,这个问题应该在8位MCU部分提出。
以上来自于百度翻译 以下为原文 The crystal ball says..... It's a bit tough without seeing any code or a schematic. And this is not really an MPLABX IDE issue, this question should be asked in the 8 bit MCU section. |
DACOUT引脚将不会驱动任何东西。需要添加缓冲区。大多数PIC数据表显示了电压跟随电路。这个没有。作为参考,参见图17-2在PIC16F1823数据表上的一个例子。
以上来自于百度翻译 以下为原文 The DACOUT pin will not drive anything. You need to add a buffer. Most of the PIC data sheets show a voltage follower circuit. This one does not. For reference look at fig. 17-2 on the PIC16F1823 data sheet for an example. |
我所要做的就是激活我的MOSFET上的门,而不是驱动LED。
以上来自于百度翻译 以下为原文 All I'm trying to do is activate the gates on my mosfets, not drive the LEDS. |
如上所述,张贴你的代码和示意图,否则只是猜测。DAC配置正确吗?启用输出?看,只是猜测。
以上来自于百度翻译 以下为原文 As stated, post your code and schematic otherwise it is just a guess. Do you have the DAC configured properly? Outputs enabled? See, just guesses. |
我们将等待您发布示意图和编码,但请记住,用5k单位电阻值,几乎没有电流驱动任何东西,甚至栅电容和栅泄漏。如果您正在使用DACUT1,请确保在测试期间断开程序员。此引脚与ICSPDAT共享。
以上来自于百度翻译 以下为原文 We will wait for you to post schematics and code but keep in mind with a 5k unit resistor value there is very little current to drive anything, even gate capacitance and gate leakage. Make sure you are disconnecting the programmer during testing if you are using DACOUT1. This pin is shared with ICSPDAT. |
他根本不使用DAC输出。参见:HTTP://www. McCHIP.COM/FUMMS/M952170.ASPX
以上来自于百度翻译 以下为原文 He's not using a DAC output at all. See: http://www.microchip.com/forums/m952270.aspx |
哇,OP想知道哪种方法会得到最大的关注吗?还是只是探索选择?最好是保持在一个线程,我想,或者至少在同一个论坛!
以上来自于百度翻译 以下为原文 Wow, is the OP trying to see which approach will get the most attention? Or just exploring options? Would be better to keep it all in one thread I would have thought, or at least in the same forum! |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
508 浏览 0 评论
5813 浏览 9 评论
2351 浏览 8 评论
2238 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3545 浏览 3 评论
1164浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
508浏览 0评论
/9
GMT+8, 2025-12-15 14:09 , Processed in 0.922018 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1923
