电子发烧友论坛|
你好,
我遇到了SPC560P60的问题。上电复位后,我停留在ram init函数,等待RGM中的POR标志。我的SW区分复位源,如果它是POR,我正在初始化SRAM。 但在这种情况下,我正在进行POR,并且在POR之后无法看到相应的标志,而我的SW被SWT卡住并重置。 彼得 #reset#spc56xp60 #rgm 以上来自于谷歌翻译 以下为原文 Hello, I have encountered problem with my SPC560P60. After power on reset I am stuck at ram init function waiting for POR flag in RGM. My SW distinguish between reset sources and if it is POR I am initializing SRAM. But in this case I am doing POR and cannot see the corresponding flags after POR and my SW get stuck and reset by SWT. Peter #reset #spc56xp60 #rgm |
3个回答
你好彼得,
您是否尝试重置FES和DES? https://community.st.com/0D50X00009XkWgeSAF 最好的祝福 二万 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello Peter , Did you try to reset FES and DES ? https://community.st.com/0D50X00009XkWgeSAF Best regards Erwan Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
嗨,
嗯,正如我所写,我正在分析重置源,如果它是POR我正在初始化RAM。 如果我擦掉FES和DES会给我带来什么好处? 我知道有POR,因为我在船上做了电源,但你的微观并没有在DES中报告。 因此我的SW崩溃,因为我没有初始化RAM。 彼得 以上来自于谷歌翻译 以下为原文 Hi, ehm, as I have wrote I am analyzing reset sources and if it was POR I am initializing RAM. If I erase FES and DES what advantage this brings to me? I know there was POR, as I did power on board, but your micro isn't reporting that in DES. And therefore my SW crash as I have no RAM initialized. Peter |
你好彼得,
你能检查一下其他的旗帜吗? '检测到1.2 V低压或2.7 V低压时,F_POR标志自动清零 检测。这意味着如果上电序列不是单调的(即, 电压上升然后下降足以触发低压检测),F_POR标志 可能未设置,而是设置< register> F_LVD12或< register> F_LVD27_VREG标志 退出重置序列。因此,如果是F_POR,则< register> F_LVD12或 < register> F_LVD27_VREG标志在复位退出时设置,软件应解释复位 导致开机。最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Peter , Could you check the others flags ? 'The F_POR flag is automatically cleared on a 1.2 V low-voltage detected or a 2.7 V lowvoltage detected. This means that if the power-up sequence is not monotonic (i.e., the voltage rises and then drops enough to trigger a low-voltage detection), the F_POR flag may not be set but instead the on exiting the reset sequence. Therefore, if the F_POR, cause as power-on.' Best regards Erwan |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 04:29 , Processed in 0.535326 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2906
