电子发烧友论坛扫一扫,分享给好友
我已经把FieleTOS移植到PSoC 4上了,这真的非常微不足道。这只是皮质M0端口,具有PSoC 5演示的一些配置和胶水。
所附的演示应用程序创建三个任务,切换PSOC 4先锋板上的红色、绿色和蓝色LED以稍微不同的速率,从而带来令人愉悦的(如果有点迷幻的)灯光表演。为自己的目的适应这个演示应该是直接的。 请注意,因为PSoC CAPSENSE组件使(无文档化)使用SyBoT定时器,所以目前不可能使用FrRetos和PSoC CAPSYSE组件一起使用。 免费邮编 1.5兆字节 以上来自于百度翻译 以下为原文 I've ported FreeRTOS to PSoC 4 - which really was extremely trivial. It's simply the Cortex M0 port with some configuration & glue from the PSoC 5 demo. The attached demo app creates three tasks that toggle the red, green and blue LEDs on the PSoC 4 pioneer board at slightly different rates, resulting in a pleasing (if somewhat psychedelic) light show. Adapting this demo for your own purposes should be straightforward. Note that because the PSoC Capsense component makes (undocumented) use of the systick timer, it's not currently possible to use FreeRTOS and the PSoC Capsense component together.
1 条评论
7个回答
嗨,Nick,
非常感谢这个实现。 当做, 维克托 以上来自于百度翻译 以下为原文 Hi Nick, many thanks for this implementation. Regards, Viktor |
更正:CAPSENSE不使用SyTobe;问题是一个无关的中断问题。
以上来自于百度翻译 以下为原文 Correction: Capsense does not use SysTick; the issue was an unrelated interrupt problem. |
简短的回答:没有。
长的回答:如果没有FriRoTOS,这将是不可能的——在PSoC上没有任何软件/驱动程序支持这个WiFi软件(不管哪一个)。但你可以随时查看你的WiFi软件的支持系统列表,也许你很幸运: 以上来自于百度翻译 以下为原文 Short answer: no. Long answer: this would not even be possible without FreeRTOS - there won't be any software / driver support for this WiFi dongle on the PSoC (no matter which one). But you can always check the list of supported systems for your WiFi dongle, maybe you are lucky :) |
嘿,Nick,
谢谢你的执行。 我在PSOC 4 BLE上使用您的示例项目。这个柜台的营业时间是多少?如果它是可配置的,它是如何配置的?我在设计范围内的资源文件中找不到任何东西,还是通过搜索代码?我们可以使用外部时钟(WCO)作为我的蜱源吗? 空闲时有可能进入睡眠模式吗? 当做, 尼利什 以上来自于百度翻译 以下为原文 Hey Nick, Thanks for the implementation. I am using your sample project on PSOC 4 BLE. What is the period of this counter? If it's configurable, how is it configured? I can't find anything in the design-wide resources file or by searching the code? Can we use external clock (WCO) as my tick source? Is it possible to go sleep mode when idle? Regards, Nilesh |
我的问题是,在PoSO4上同时运行实时操作系统,可以运行吗?
以上来自于百度翻译 以下为原文 My question is, in PSOC4 BLE to run on RTOS of at the same time, can run BLE? |
谢谢你,Nick,我把RTOS演示项目移植到我的PSoC 4 BLUE,它在更新组件之后工作得很好。
以上来自于百度翻译 以下为原文 Thank you Nick, i ported the RTOS demo project to my PSoC 4 BLE and it worked fine after updating the components. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 08:57 , Processed in 0.729907 second(s), Total 97, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1586
