你好,
我定义了一个另一个端点在FX2LP Slave FIFO固件,4X,散装(登记设置>;ep2cfg = 0xA0;) 如果我点击transferout按钮的时候,批量转移是successfull.if我transferout按钮点击超过4次,其给予997的误差。 如果我改变登记设置为ep2cfg = 0xa2;即,2X,散装,如果我transferout按钮点击超过2次,其给予997的误差,前两次请求working.whats问题。 当做, 吉萨 以上来自于百度翻译 以下为原文 HI, I have defined an another endpoint 2 in fx2lp slave fifo firmware with OUT,4x ,Bulk (register settings -> EP2CFG = 0xA0;) if i click transferout button times,bulk out transfer is successfull.if i click transferout button more than 4 times,its giving 997 error. if i change register setting as EP2CFG = 0xA2; that is OUT,2x,bulk and if i click transferout button more than 2 times,its giving 997 error,first two times request is working.whats the issue. regards, geetha. |
5个回答
你好Geethanjali,
这不是一个问题。这是怎样的FX2LP预计工作。当你配置端点为四缓冲(4x),四转让出去后,在FX2LP的缓冲区填充。这些数据需要清空。只有这样,FX2LP能够从主机接收下一个数据。 诚挚的问候, Srinath的 以上来自于百度翻译 以下为原文 Hello Geethanjali, This is not an issue. This is how the FX2LP is expected to work. When you have configured the endpoint as quad buffered (4x), after 4 'Transfer Out's, the buffers in the FX2LP are filled. This data needs to be emptied. Only then, FX2LP will be able to receive the next data from the host. Best regards, Srinath S |
wangcong12138 发表于 2018-8-19 04:11 你好,克里斯纳特, 如何清空填充缓冲器?有什么特殊的寄存器吗? 当做, 吉萨 以上来自于百度翻译 以下为原文 Hello shrinath, how to emptied filled buffers?is any speccific registers are there? regards, geetha. |
你好,Geethanjali, 这取决于你的实现。请阅读EZ-USB技术参考手册的注册信息。 HTTP://www. CyPress .COM/FIL/12646/下载 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Geethanjali, It depends on your implementation. Kindly, read through the EZ-USB Technical Reference Manual for register information. http://www.cypress.com/file/126446/download Best regards, Srinath S |
wangcong12138 发表于 2018-8-19 04:36 你好,克里斯纳特, 我试图将端点数据的端点缓冲区。 休息后的FIFO也,问题是相同的。 tdIn() { EP2FIFOCFG=0x00;//OutoMod=0; //EP2FIFOFFG=0x10;//OutoMod=1; } TDYPOLL() { FIFSET=0x80;//重置FIFO 同步延迟; FippET= 0x82. 同步延迟; FippET= 0x00; 同步延迟; EP2BCH=0x02;/ / 512字节提交 同步延迟; EP2BCl=0x00; 同步延迟; } 以上来自于百度翻译 以下为原文 Hello shrinath, I am trying to store OUT endpoint data in the endpoint buffer. after resting the FIFO also, the problem is same. TD_INIT() { EP2FIFOCFG = 0x00; //automode=0; //EP2FIFOCFG = 0x10; //automode=1; } TD_poll() { FIFORESET = 0x80; // Reset the FIFO SYNCDELAY; FIFORESET = 0x82; SYNCDELAY; FIFORESET = 0x00; SYNCDELAY; EP2BCH=0x02; //512 bytes committed SYNCDELAY; EP2BCL=0x00; SYNCDELAY; } |
你好,克里斯纳特, 任何示例/项目都有空清空缓冲区吗? 当做, 吉萨 以上来自于百度翻译 以下为原文 Hello shrinath, any example/projects are there to empty the OUT buffer? regards, geetha. |
只有小组成员才能发言,加入小组>>
751个成员聚集在这个小组
加入小组2063 浏览 1 评论
1823 浏览 1 评论
3631 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1759 浏览 6 评论
1507 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
501浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
353浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
408浏览 2评论
353浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
850浏览 2评论
GMT+8, 2024-11-19 10:45 , Processed in 2.234670 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
