电子发烧友论坛|
您好,我正在尝试做PoSO5LP启动程序与先锋工具包工作。我可以建立一个项目并写入P5LP,根据先锋工具包用户指南-6.3.1在编写程序后为PSoC 5LP构建可引导加载项目,P5LP正在按预期工作。但是,当每次重置此时,P5LP进入引导加载模式。我再也不能进入工作模式了。有人知道这件事,请告诉我。
以上来自于百度翻译 以下为原文 Hello, I am trying to do PSoC5LP bootable program work with Pioneer Kit. I can build a project and write into P5LP, According to Pioneer Kit User guide - 6.3.1 Building a Bootloadable project for the PSoC 5LP After writting a program, P5LP is working as expected. But, when everytime resetting this, P5LP enter to boot-loading mode. I can't enter to working mode, never again. Does anyone knows around this, please let me know. |
2个回答
如果可能的话(使用PSoC4,我也考虑PSOC5),用Bootloader +应用程序结合的HEX文件编程PSoC,并调试Bootloader一个与PSoC Creator“调试而不编程”。做到这一点,留下闪光灯还有应用部分。如果Flash的应用程序部分没有被赋予它,例如一个校验和不匹配到Flash的元数据部分(最后一个Flash行的一半),则引导加载程序生成的代码停留在Bootloader模式中。重置后跟踪Bootloader会捕获应用程序启动丢失的原因。
法维奥 以上来自于百度翻译 以下为原文 If possible (with PsoC4 is it so I think also with PSoC5), program the PSoC with the bootloader+application combined hex file and than debug the bootloader one with the PSoC Creator "debug without programming". Do this to leave the flash with also the application part. The bootloader generated code stays in bootloader mode if the application part of flash isn't as aspected to it, for example with a checksum that doesn't match with one into metadata part of flash (half of last flash row). Tracing bootloader after a reset catch the reason for application start's missing. Fabio |
嗨FFTORON SAN“KONNITIWA”非常感谢你的回答。最后,在P5LP上找到了一个激活自己程序的方法。需要激活PSoC4芯片,当WnAT进入P5LP工作模式(非引导加载模式)以设置J13(on)到目前为止,我发现了一个有趣的Bootloader文章[HTP://www. eltMe1.com /Cuulthy/thRead /27 067?TSt= 0:这是自举器。再次谢谢你。
以上来自于百度翻译 以下为原文 Hi ftoffolon-san "Konnitiwa" Thank you so much for your answer. Finally, I find a way to activate own program on P5LP. Need to activate PSoC4 chip, when wnat to enter P5LP working-mode (not boot-loading mode) To set J13(ON) that is OK So far, I find a interesting article of Bootloader [ http://www.element14.com/community/thread/27067?tstart=0 ] This is Bootloader it self. Thank you again. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 02:12 , Processed in 4.034029 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2526
