你好!在PIC24FJ16GA004上,如果使用RTCC,那么主核必须共享RTCC(SOSC)时钟,这是否正确?难道不可能尽可能快地对核心进行时钟(8M+PLL)并以它同时需要的频率对RTCC进行时钟吗?从我能看到的,我被困在32.768千赫,可以这样吗?非常感谢!
以上来自于百度翻译 以下为原文 Hello! Am I right in thinking that on PIC24FJ16GA004, if using the RTCC, then the main core has to share the RTCC's (SOSC) clock? Is it not possible to clock the core as fast as possible (8M+PLL) and clock the RTCC at the frequency it requires at the same time? From what I can see, I'm stuck with everything going at 32.768KHz, can this be so? Thanks very much! |
3个回答
核心可以从“正常”时钟运行,而RTCC从SOSC(或T1CK)运行。这就是第二个OSC的原因。这有帮助吗?
以上来自于百度翻译 以下为原文 The core can run from the 'normal' clock while the RTCC runs from SOSC (or T1CK). This is the reason for this SECONDary OSC. Does this help? |
是什么让你认为你必须从SOSC中运行核心?
以上来自于百度翻译 以下为原文 What makes you think you have to run the main core from SOSC? |
你好!谢谢您。这是令人安心的,我认为事情一定是这样。我很快就要回去了,也许星期五我只是很无聊。我相信我会整理好的。谢谢,我真的很感激这个答案!
以上来自于百度翻译 以下为原文 Hi! Thank you. Well, that's reassuring and how I thought things must be. I need to get back into it shortly, perhaps I was just being very dull on Friday. I'm sure I'll sort it out now. Thank you, I do appreciate the answer! |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 03:40 , Processed in 0.608805 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
501
