我正在制作一个我正在获取数据的项目。
每个数据等于一个内存地址。我希望为每个内存地址添加1 内存的时钟是数据的两倍,然后是数据的时钟,因此ican获取此内存地址中的值,然后加1 在测试台我发送计数器的数据,所以每个地址的值应为1 问题是写入比双倍速率时钟周期花费更多时间,因此我以1,2,3,4 ... N结束,而不是每个地址都有1 我检查了内存可以工作的频率& 它大约是150MHz。 我使用的是50ns时钟,其中一半是双时钟频率,我仍然有我提到的延迟 有没有人知道为什么会这样 谢谢每个人! 以上来自于谷歌翻译 以下为原文 i am making a project where i am getting data. each data is equal to a memory address.i want to add 1 to each of this memory addresses the clock of the memory is twice fater then the clock of the data so i can get the value in this memory address and then add 1 in the test bench i am sending data of a counter so every address should have value of 1 the problem is the write takes me more time then the double rate clock period so i am ending with 1,2,3,4...N and not with 1 in every address i checked the frequency in wich the memory can work & it is about 150MHz. i am using a 50ns clock and half of this is the double clock rate and still i have the delay i mentioned does any one have any idea why is that thank for every body!!! |
6个回答
你能发布你的代码吗?
这听起来像你没有看到 读取正确时钟周期的数据。 递增模式你 如果Block RAM以默认模式运行,则会发生描述 写入优先,你正在查看第一个读取数据 地址稳定的两个周期。 这实际上会给你 由于直写逻辑,从先前地址写入数据 在块RAM中。 读取数据实际上在第二次有效 在有效地址的两个周期中,您需要进行添加 组合(没有时钟延迟)。 问候, 的Gabor - Gabor 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Can you post your code? It sounds to me like you are not looking at the read data on the correct clock cycle. The incrementing pattern you describe would happen if the Block RAM is running in the default mode of write-first, and you are looking at the read data on the first of the two cycles that your address is stable. This would actually give you the write data from the previous address due to the write-through logic in the block RAM. The read data is actually valid during the second of the two cycles of valid address, so your addition needs to happen combinatorially (without a clock delay). Regards, Gabor -- GaborView solution in original post |
如果您正在使用Block RAM,则需要注意内存上有一个寄存器
读取输出,以便在应用地址后,旧数据在循环中出现。 然后 你的添加需要在你写回内存的同一个时钟周期内发生。 所以 你有一个时钟周期:输出时间的内存加上组合 加法器的延迟和写入内存的设置时间。 如果您发现需要管道 除了满足时序(我不确定你在25 ns时做),那么你需要更多的时钟周期 或者你需要改变你的方法来交替连续的读写周期 数据输入。 我在Virtex 5上使用后一种方法在200 MHz,所以它不应该 Spartan 3在40 MHz时出现的任何问题。 我仍然对你的陈述感到有点困惑 “写入比双倍时钟周期花费更多时间” 这是真实硬件还是您的测试平台在行为期间向您展示这一点 模拟? 问候, 的Gabor - Gabor 以上来自于谷歌翻译 以下为原文 If you are using block RAM, you need to be aware that the memory has a register on the read output so the old data comes out on the cycle after you apply the address. Then your addition needs to happen in the same clock cycle you write the memory back. So you have in one clock cycle: the clock to output time of the memory plus the combinatorial delay of your adder and the setup time to write memory. If you find that you need to pipeline the addition to meet timing (I'm not sure you do at 25 ns) then you would need more clock cycles or you need to change your approach to interleave read and write cycles from successive data inputs. I have used the latter approach on Virtex 5 at 200 MHz, so it shouldn't have any problems in Spartan 3 at 40 MHz. Still I'm a bit confused on your statement "the write takes me more time then the double rate clock period" Is this in the real hardware or is your testbench showing you this during behavioral simulation? Regards, Gabor -- Gabor |
首先感谢您的时间和知识
作为你的问题的答案,我在测试台上看到了这一点(行为模仿) 我认为你是对的,在40Mhz中实现它不应该是一个问题 (我用xilinxdefinitions检查) 问候 埃菲 以上来自于谷歌翻译 以下为原文 first thank you for your time and knowledge as an answer to your question i ment that i see that in test bench (behavioral imulation) i think that you are right and it not supposed to be a problem to implement that in 40Mhz ( i check that with xilinx definitions ) regards Efi |
你能发布你的代码吗?
这听起来像你没有看到 读取正确时钟周期的数据。 递增模式你 如果Block RAM以默认模式运行,则会发生描述 写入优先,你正在查看第一个读取数据 地址稳定的两个周期。 这实际上会给你 由于直写逻辑,从先前地址写入数据 在块RAM中。 读取数据实际上在第二次有效 在有效地址的两个周期中,您需要进行添加 组合(没有时钟延迟)。 问候, 的Gabor - Gabor 以上来自于谷歌翻译 以下为原文 Can you post your code? It sounds to me like you are not looking at the read data on the correct clock cycle. The incrementing pattern you describe would happen if the Block RAM is running in the default mode of write-first, and you are looking at the read data on the first of the two cycles that your address is stable. This would actually give you the write data from the previous address due to the write-through logic in the block RAM. The read data is actually valid during the second of the two cycles of valid address, so your addition needs to happen combinatorially (without a clock delay). Regards, Gabor -- Gabor |
只想对你的时间说谢谢
你可以看到问题已经解决了。谢谢 以上来自于谷歌翻译 以下为原文 just want to say TNX for your time as you can see the problem was solved THANKS |
我(kamal)想要在fpga上做我的主要项目。我的clg提供了xilinx spartan 3e xcs100e fpga board..so请帮我决定项目的主题..我的电子邮件ID是kamal.bhugra7@gmail.com
以上来自于谷歌翻译 以下为原文 i (kamal) want to make my major project on fpga..my clg provided me xilinx spartan 3e xcs100e fpga board..so kindly help me in deciding topic of the project.. my email id is kamal.bhugra7@gmail.com |
只有小组成员才能发言,加入小组>>
2305 浏览 7 评论
2714 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2196 浏览 9 评论
3277 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2349 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
625浏览 1评论
1679浏览 1评论
186浏览 1评论
648浏览 0评论
1835浏览 0评论
GMT+8, 2024-9-18 23:25 , Processed in 1.375519 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
