花了近1个月的时间写完了飞控代码 准备调PID了 结果发现无论怎么给油门PWM高电平持续时间被压制在了0.999ms 真尼玛恶心
现在束手无策 不知道从哪里找问题 求大神指点迷津 代码量有点大 我分楼发吧 |
10个回答
先是I2C与MPU6050
#include #include #define SCL_Pin GPIO_Pin_10 #define SDA_Pin GPIO_Pin_11 #define SCL_H {GPIOB->BSRRH = SCL_Pin;I2C_delay(4);} //SCL¸ßµçƽ #define SCL_L {GPIOB->BSRRL = SCL_Pin;I2C_delay(4);} //SCLµÍµçƽ #define SDA_H {GPIOB->BSRRH = SDA_Pin;I2C_delay(4);} //SDA¸ßµçƽ #define SDA_L {GPIOB->BSRRL = SDA_Pin;I2C_delay(4);} //SDAµÍµçƽ #define SDA_Read GPIOB->IDR & SDA_Pin //SDA¶ÁÊý¾Ý uint8_t GYRO_Offset = 0;//²»×Ô¶¯Ð£Õý uint8_t ACC_Offset = 0; uint32_t I2C_Erro=0; static uint8_t MPU6050_Buffer[14]; void I2C2_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB , ENABLE); //´ò¿ªÍâÉèBµÄʱÖÓ GPIO_InitStructure.GPIO_Pin = Debug1_Pin | Debug2_Pin | Debug3_Pin; //ÓÃÓÚ²âÁ¿³ÌÐòÔËÐÐËÙÂÊ GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType= GPIO_OType_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = SCL_Pin; //SCL GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType= GPIO_OType_OD; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = SDA_Pin; //SDA GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType= GPIO_OType_OD; GPIO_Init(GPIOB, &GPIO_InitStructure); } static void I2C_delay(int delay) { while (delay) delay--; } static uint8_t I2C_Start(void) { SCL_L; SDA_H; SCL_H; if(!SDA_Read) return 0; //SDAÏßΪµÍµçƽÔò×ÜÏßæ,Í˳ö SDA_L; if(SDA_Read) return 0; //SDAÏßΪ¸ßµçƽÔò×ÜÏß³ö´í,Í˳ö SDA_L; return 1; } static void I2C_Stop(void) { SCL_L; SDA_L; SCL_H; SDA_H; } static void I2C_ACK(void) { SCL_L; __nop(); SDA_L; //дӦ´ðÐźŠ__nop(); SCL_H; __nop(); SCL_L; } static void I2C_NACK(void) { SCL_L; // __nop(); SDA_H; //²»Ð´Ó¦´ðÐźŠ// __nop(); SCL_H; // __nop(); SCL_L; } static uint8_t I2C_WaitAck(void) { SCL_L; SDA_H; SCL_H; if(SDA_Read) { SCL_L; return 0; } SCL_L; return 1; } static void I2C_WriteByte(unsigned char SendByte) { uint8_t i=8; while(i--) { SCL_L; if( SendByte&0x80 ) SDA_H else SDA_L SendByte <<= 1; SCL_H; } SCL_L; } static uint8_t I2C_ReadByte(void) { uint8_t i=8; uint8_t ReceiveByte =0; SDA_H; while(i--) { SCL_L; __nop(); SCL_H; ReceiveByte <<= 1; if(SDA_Read) ReceiveByte |= 0x01; } SCL_L; return ReceiveByte; } static uint8_t Single_WriteI2C(unsigned char Regs_Addr,unsigned char Regs_Data) { if( !I2C_Start() ) return 0; //I2CÆðʼ´íÎ󣬷µ»Ø I2C_WriteByte(MPU6050Address); //дSlaveµØÖ·£¬²¢ÅäÖóÉдģʽ if( !I2C_WaitAck() ) { I2C_Stop(); return 0; //ÎÞACK£¬·µ»Ø } I2C_WriteByte(Regs_Addr); //д¼Ä´æÆ÷µØÖ· I2C_WaitAck(); I2C_WriteByte(Regs_Data); //д¼Ä´æÆ÷Êý¾Ý I2C_WaitAck(); I2C_Stop(); return 1; } static uint8_t Single_ReadI2C(unsigned char Regs_Addr) { uint8_t ret; if( !I2C_Start() ) return 0; //I2CÆðʼ´íÎ󣬷µ»Ø I2C_WriteByte(MPU6050Address); //дSlaveµØÖ·£¬²¢ÅäÖóÉдģʽ if( !I2C_WaitAck() ) { I2C_Stop(); return 0; //ÎÞACK£¬·µ»Ø } I2C_WriteByte(Regs_Addr); //д¼Ä´æÆ÷µØÖ· I2C_WaitAck(); I2C_Start(); I2C_WriteByte(MPU6050Address+1);//дSlaveµØÖ·£¬²¢ÅäÖóɶÁģʽ I2C_WaitAck(); ret=I2C_ReadByte(); //´Ó´«¸ÐÆ÷ÖжÁ³öÊý¾Ý I2C_NACK(); //ÎÞÓ¦´ð I2C_Stop(); //½áÊø±¾¶ÎIIC½ø³Ì return ret; } uint8_t MPU6050_SequenceRead(void) { uint8_t index=14; if( !I2C_Start() ) return 0; //I2CÆðʼ´íÎ󣬷µ»Ø I2C_WriteByte(MPU6050Address); //дSlaveµØÖ·£¬²¢ÅäÖóÉдģʽ if( !I2C_WaitAck() ) { I2C_Stop(); return 0; //ÎÞACK£¬·µ»Ø } I2C_WriteByte(ACCEL_XOUT_H); //д¼Ä´æÆ÷µØÖ· I2C_WaitAck(); I2C_Start(); I2C_WriteByte(MPU6050Address+1);//дSlaveµØÖ·£¬²¢ÅäÖóɶÁģʽ I2C_WaitAck(); while(--index) //Á¬¶Á13λ¼Ä´æÆ÷ { MPU6050_Buffer[13 - index] = I2C_ReadByte(); I2C_ACK(); } MPU6050_Buffer[13] = I2C_ReadByte(); //¶ÁµÚ14¼Ä´æÆ÷ I2C_NACK(); I2C_Stop(); return 1; } void MPU6050_SingleRead(void) { MPU6050_Buffer[0] = Single_ReadI2C(ACCEL_XOUT_H); MPU6050_Buffer[1] = Single_ReadI2C(ACCEL_XOUT_L); MPU6050_Buffer[2] = Single_ReadI2C(ACCEL_YOUT_H); MPU6050_Buffer[3] = Single_ReadI2C(ACCEL_YOUT_L); MPU6050_Buffer[4] = Single_ReadI2C(ACCEL_ZOUT_H); MPU6050_Buffer[5] = Single_ReadI2C(ACCEL_ZOUT_L); MPU6050_Buffer[8] = Single_ReadI2C(GYRO_XOUT_H); MPU6050_Buffer[9] = Single_ReadI2C(GYRO_XOUT_L); MPU6050_Buffer[10] = Single_ReadI2C(GYRO_YOUT_H); MPU6050_Buffer[11] = Single_ReadI2C(GYRO_YOUT_L); MPU6050_Buffer[12] = Single_ReadI2C(GYRO_ZOUT_H); MPU6050_Buffer[13] = Single_ReadI2C(GYRO_ZOUT_L); } uint8_t InitMPU6050(void) { if( Single_ReadI2C(WHO_AM_I) != 0x68)//¼ì²éMPU6050ÊÇ·ñÕý³£ { return 0; } Single_WriteI2C(PWR_MGMT_1, 0x00); //µçÔ´¹ÜÀí£¬µäÐÍÖµ£º0x00£¬Õý³£Ä£Ê½ I2C_delay(20000); //Ô¼2.5msÑÓʱ Single_WriteI2C(SMPLRT_DIV, 0x00); //ÍÓÂÝÒDzÉÑùÂÊ£¬µäÐÍÖµ£º0x00£¬²»·ÖƵ£¨8KHZ£© I2C_delay(20000); Single_WriteI2C(CONFIG2, 0x00); //µÍͨÂ˲¨ÆµÂÊ£¬µäÐÍÖµ£º0x00£¬²»ÆôÓÃMPU6050×Ô´øÂ˲¨ I2C_delay(20000); Single_WriteI2C(GYRO_CONFIG, 0x18); //ÍÓÂÝÒÇ×Լ켰²âÁ¿·¶Î§£¬µäÐÍÖµ£º0x18(²»×Լ죬2000deg/s) I2C_delay(20000); Single_WriteI2C(ACCEL_CONFIG, 0x1F);//¼ÓËÙ¼Æ×Լ졢²âÁ¿·¶Î§¼°¸ßͨÂ˲¨ÆµÂÊ£¬µäÐÍÖµ£º0x1F(²»×Լ죬16G) I2C_delay(20000); return 1; } void MPU6050_Compose(void) { acc.x = ((((int16_t)MPU6050_Buffer[0]) << 8) | MPU6050_Buffer[1]) - offset_acc.x; //¼õÈ¥ÁãÆ« acc.y = ((((int16_t)MPU6050_Buffer[2]) << 8) | MPU6050_Buffer[3]) - offset_acc.y; acc.z = ((((int16_t)MPU6050_Buffer[4]) << 8) | MPU6050_Buffer[5]) - offset_acc.z; gyro.x = ((((int16_t)MPU6050_Buffer[8]) << 8) | MPU6050_Buffer[9]) - offset_gyro.x; gyro.y = ((((int16_t)MPU6050_Buffer[10]) << 8) | MPU6050_Buffer[11]) - offset_gyro.y; gyro.z = ((((int16_t)MPU6050_Buffer[12]) << 8) | MPU6050_Buffer[13]) - offset_gyro.z; } |
然后是滤波
static float ACC_IIR_FACTOR; void Calculate_FilteringCoefficient(float Time, float Cut_Off) { ACC_IIR_FACTOR = Time /( Time + 1/(2.0f*Pi*Cut_Off) ); } void ACC_IIR_Filter(struct _acc *Acc_in,struct _acc *Acc_out) { Acc_out->x = Acc_out->x + ACC_IIR_FACTOR*(Acc_in->x - Acc_out->x); Acc_out->y = Acc_out->y + ACC_IIR_FACTOR*(Acc_in->y - Acc_out->y); Acc_out->z = Acc_out->z + ACC_IIR_FACTOR*(Acc_in->z - Acc_out->z); } #define Filter_Num 2 void Gyro_Filter(struct _gyro *Gyro_in,struct _gyro *Gyro_out) { static int16_t Filter_x[Filter_Num],Filter_y[Filter_Num],Filter_z[Filter_Num]; static uint8_t Filter_count; int32_t Filter_sum_x=0,Filter_sum_y=0,Filter_sum_z=0; uint8_t i=0; Filter_x[Filter_count] = Gyro_in->x; Filter_y[Filter_count] = Gyro_in->y; Filter_z[Filter_count] = Gyro_in->z; for(i=0;i Filter_sum_x += Filter_x; Filter_sum_y += Filter_y; Filter_sum_z += Filter_z; } Gyro_out->x = Filter_sum_x / Filter_Num; Gyro_out->y = Filter_sum_y / Filter_Num; Gyro_out->z = Filter_sum_z / Filter_Num; Filter_count++; if(Filter_count == Filter_Num) Filter_count=0; } |
角速度转弧度制
#include "Maths.h" #include "struct_all.h" void Get_Radian(struct _gyro *Gyro_in,struct _SI_float *Gyro_out) { Gyro_out->x = (float)(Gyro_in->x * RawData_to_Radian); Gyro_out->y = (float)(Gyro_in->y * RawData_to_Radian); Gyro_out->z = (float)(Gyro_in->z * RawData_to_Radian); } float invSqrt(float x) { float halfx = 0.5f * x; float y = x; long i = *(long*)&y; i = 0x5f3759df - (i>>1); y = *(float*)&i; y = y * (1.5f - (halfx * y * y)); return y; } |
四元数转姿态角
#include #include #include #include #define Kp 1.0f // ±ÈÀý³£Êý #define Ki 0.001f // »ý·Ö³£Êý #define halfT 0.0005f//°ëÖÜÆÚ #define T 0.001f // ÖÜÆÚΪ1ms float q0 = 1, q1 = 0, q2 = 0, q3 = 0; // ËÄÔªÊý float exInt = 0, eyInt = 0, ezInt = 0; // Îó²î»ý·ÖÀÛ¼ÆÖµ void IMUpdate(float gx, float gy, float gz, float ax, float ay, float az) { float norm; float vx, vy, vz; float ex, ey, ez; //ËÄÔªÊý»ý·Ö£¬ÇóµÃµ±Ç°µÄ×Ë̬ float q0_last = q0; float q1_last = q1; float q2_last = q2; float q3_last = q3; //°Ñ¼ÓËٶȼƵÄÈýάÏòÁ¿×ª³Éµ¥Î»ÏòÁ¿ norm = invSqrt(ax*ax + ay*ay + az*az); ax = ax * norm; ay = ay * norm; az = az * norm; //¹À¼ÆÖØÁ¦¼ÓËٶȷ½ÏòÔÚ·ÉÐÐÆ÷×ø±êϵÖеıíʾ£¬ÎªËÄÔªÊý±íʾµÄÐýת¾ØÕóµÄµÚÈýÐÐ vx = 2*(q1*q3 - q0*q2); vy = 2*(q0*q1 + q2*q3); vz = q0*q0 - q1*q1 - q2*q2 + q3*q3; //¼ÓËٶȼƶÁÈ¡µÄ·½ÏòÓëÖØÁ¦¼ÓËٶȷ½ÏòµÄ²îÖµ£¬ÓÃÏòÁ¿²æ³Ë¼ÆËã ex = ay*vz - az*vy; ey = az*vx - ax*vz; ez = ax*vy - ay*vx; //Îó²îÀÛ»ý£¬ÒÑÓë»ý·Ö³£ÊýÏà³Ë exInt = exInt + ex*Ki; eyInt = eyInt + ey*Ki; ezInt = ezInt + ez*Ki; //Óòæ»ýÎó²îÀ´×öIÐÞÕýÍÓÂÝÁãÆ«£¬¼´µÖÏûÍÓÂݶÁÊýÖеÄÆ«ÒÆÁ¿ gx = gx + Kp*ex + exInt; gy = gy + Kp*ey + eyInt; gz = gz + Kp*ez + ezInt; //Ò»½×½üËÆËã·¨ q0 = q0_last + (-q1_last*gx - q2_last*gy - q3_last*gz)*halfT; q1 = q1_last + ( q0_last*gx + q2_last*gz - q3_last*gy)*halfT; q2 = q2_last + ( q0_last*gy - q1_last*gz + q3_last*gx)*halfT; q3 = q3_last + ( q0_last*gz + q1_last*gy - q2_last*gx)*halfT; //ËÄÔªÊý¹æ·¶»¯ norm = invSqrt(q0*q0 + q1*q1 + q2*q2 + q3*q3); q0 = q0 * norm; q1 = q1 * norm; q2 = q2 * norm; q3 = q3 * norm; out_angle.yaw += filter_gyro.z * RawData_to_Angle * 0.001f; } void Get_Eulerian_Angle(struct _out_angle *angle) { angle->pitch = -atan2(2.0f*(q0*q1 + q2*q3),q0*q0 - q1*q1 - q2*q2 + q3*q3)*Radian_to_Angle; angle->roll = asin (2.0f*(q0*q2 - q1*q3))*Radian_to_Angle; } |
串级PID
#include "Maths.h" #include "Control.h" #include "struct_all.h" float thr=0; float Pitch_i,Roll_i,Yaw_i; float Pitch_old,Roll_old,Yaw_old; float Pitch_d,Roll_d,Yaw_d; float RC_Pitch=0,RC_Roll=0,RC_Yaw=0; float Pitch_shell_out,Roll_shell_out,Yaw_shell_out; float Pitch_shell_kp=140; float Pitch_shell_ki=0.2; float Pitch_shell_kd=0.8; float Roll_shell_kp=150; float Roll_shell_ki=0.2; float Roll_shell_kd=0.8; float Yaw_shell_kp=15;//0.87 float Yaw_shell_ki=0.002; float Yaw_shell_kd=0.02; float Gyro_radian_old_x,Gyro_radian_old_y,Gyro_radian_old_z; float pitch_core_kp_out,pitch_core_ki_out,pitch_core_kd_out,Roll_core_kp_out, Roll_core_ki_out,Roll_core_kd_out,Roll_core_ki_out,Yaw_core_kp_out, Yaw_core_ki_out,Yaw_core_kd_out; float Pitch_core_out,Roll_core_out,Yaw_core_out; float Pitch_core_kp=0.02; float Pitch_core_ki=0; float Pitch_core_kd=0.001;//0.001 float Roll_core_kp=0.02; float Roll_core_ki=0; float Roll_core_kd=0.001; float Yaw_core_kp=0.001; float Yaw_core_ki=0; float Yaw_core_kd=0.001; int16_t moto1=1613,moto2=1613,moto3=1613,moto4=1613; void CONTROL_PID(struct _out_angle *angle) { RC_Pitch=(300000 -1499.0f )/50; RC_Pitch-=3.3f; Pitch_i+=(angle->pitch-RC_Pitch); if(Pitch_i>300) Pitch_i=300; else if(Pitch_i<-300) Pitch_i=-300; Pitch_d=angle->pitch-Pitch_old; Pitch_shell_out = Pitch_shell_kp*(angle->pitch-RC_Pitch) + Pitch_shell_ki*Pitch_i + Pitch_shell_kd*Pitch_d; Pitch_old=angle->pitch; RC_Roll=(300000-1502)/50; Roll_i+=(angle->roll-RC_Roll); if(Roll_i>300) Roll_i=300; else if(Roll_i<-300) Roll_i=-300; Roll_d=angle->roll-Roll_old; Roll_shell_out = Roll_shell_kp*(angle->roll-RC_Roll) + Roll_shell_ki*Roll_i + Roll_shell_kd*Roll_d; Roll_old=angle->roll; Yaw_d=SI_gyro.z-Yaw_old; Yaw_shell_out = Yaw_shell_kp*(SI_gyro.z-RC_Yaw) + Yaw_shell_ki*Yaw_i + Yaw_shell_kd*Yaw_d; Yaw_old=SI_gyro.z; pitch_core_kp_out = Pitch_core_kp * (Pitch_shell_out + SI_gyro.y ); pitch_core_kd_out = Pitch_core_kd * (SI_gyro.y - Gyro_radian_old_y); Roll_core_kp_out = Roll_core_kp * (Roll_shell_out + SI_gyro.x ); Roll_core_kd_out = Roll_core_kd * (SI_gyro.x - Gyro_radian_old_x); Yaw_core_kp_out = Yaw_core_kp * (Yaw_shell_out + SI_gyro.z); Yaw_core_kd_out = Yaw_core_kd * (SI_gyro.z - Gyro_radian_old_z); Pitch_core_out = pitch_core_kp_out + pitch_core_kd_out; Roll_core_out = Roll_core_kp_out + Roll_core_kd_out; Yaw_core_out = Yaw_core_kp_out + Yaw_core_kd_out; Gyro_radian_old_y = SI_gyro.y; Gyro_radian_old_x = SI_gyro.x; Gyro_radian_old_z = SI_gyro.z; thr=1300; moto1=(int16_t)(thr - Roll_core_out - Pitch_core_out- Yaw_core_out); moto2=(int16_t)(thr + Roll_core_out - Pitch_core_out+ Yaw_core_out); moto3=(int16_t)(thr + Roll_core_out + Pitch_core_out- Yaw_core_out); moto4=(int16_t)(thr - Roll_core_out + Pitch_core_out+ Yaw_core_out); Motor_Out(moto1,moto2,moto3,moto4); } |
主函数
#include #include #include #include #include #include #include #include #include #include int main() { delay_init(72); Nvic_Init(); drivers_init(); while(1) { if(Count_1ms>=1) { Count_1ms=0; MPU6050_SingleRead(); MPU6050_Compose(); ACC_IIR_Filter(&acc,&filter_acc); Gyro_Filter(&gyro,&filter_gyro); Get_Radian(&filter_gyro,&SI_gyro); IMUpdate(SI_gyro.x,SI_gyro.y,SI_gyro.z,filter_acc.x,filter_acc.y,filter_acc.z); } if(Count_4ms>=4) { Count_4ms=0; Get_Eulerian_Angle(&out_angle); CONTROL_PID(&out_angle); } } } |
来个大神帮帮忙啊
只有小组成员才能发言,加入小组>>
请问下图大疆lightbridge2遥控器主板电源芯片型号是什么?
4480 浏览 1 评论
使用常见的二极管、三极管和mos做MCU和模组的电平转换电路,但是模组和MCU无法正常通信,为什么?
350浏览 2评论
为了提高USIM卡电路的可靠性和稳定性,在电路设计中须注意的点有哪些?
359浏览 2评论
381浏览 2评论
374浏览 2评论
432浏览 2评论
GMT+8, 2024-12-28 14:32 , Processed in 1.101354 second(s), Total 94, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
