电子发烧友论坛|
我打算将V3500A射频功率计集成到由VEE程序控制的自动测量系统中。
我已经阅读了V3500A用户手册,它完整地讨论了VB和C ++环境中USB控制驱动程序的安装,以及作为字符串发送到仪器的命令。 但是,本手册未讨论VEE环境中V3500的控制。 我需要知道是否存在使用Agilent 15.5 IO库由VEE程序发送(和读取)命令(和仪器响应)的方法。提前感谢您的合作。 以上来自于谷歌翻译 以下为原文 I intend to integrate a V3500A RF power meter in an automated measurement system controlled by a VEE program. I have read the V3500A user manual and it discusses fully the installation of drivers for USB control in VB and C++ environments, together with the commands that are sent to the instrument as strings. However, the manual does not discuss the control of the V3500 in a VEE environment. I need to know if there exists a method for the commands (and the instrument responses) to be sent (and read) by a VEE program using Agilent 15.5 IO library. Thanks in advance for your cooperation. |
2个回答
您的仪表是否具有串行端口连接或USB直接连接?
串行驱动器往往比直接USB驱动器更容易上手,特别是如果仪表制造商不支持VEE。 如果你可以让它作为一个串行乐器工作,你可以发送字符串等,它将全部工作。 以上来自于谷歌翻译 以下为原文 Does your meter have a serial port connection or is it USB direct? Serial drivers tend to be a lot easier to get going than the direct USB one especially if the meter manufacturer does not support VEE. if you can get it to work as a serial instrument, you can then send the strings etc and it will all work. |
您好,我在Power Meter论坛上发布了回复,很明显,Tom Silchia。
以上来自于谷歌翻译 以下为原文 Hello, I posted a response in the Power Meter forum at view Sincerely, Tom Silchia. |
只有小组成员才能发言,加入小组>>
320 浏览 0 评论
1872 浏览 0 评论
2757 浏览 1 评论
2659 浏览 1 评论
2480 浏览 5 评论
1872浏览 0评论
438浏览 0评论
321浏览 0评论
/9
GMT+8, 2025-12-18 14:06 , Processed in 0.803612 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2294
