你好,我有一个VXI主机,里面有一些仪器。现在我换了一台新电脑和新的Vee。=>我需要安装什么才能使用一切?是否足以安装IO-Libararies 15或者我还需要
每个仪器的“VXI-pnp-driver”?可在Agilent网站上下载的驱动程序是从2000年开始的。它们是否仍在新的Vee和XP下运行?我的vee程序是使用面板驱动程序创建的。 这个面板驱动程序是安装的VXI-pnp驱动程序的一部分吗?感谢您提供一些信息。 以上来自于谷歌翻译 以下为原文 Hello, i have a VXI-mainframe with some instruments inside. Now i switched to a new computer and anew Vee. =>What do i have to install to use everything? Is it enough to install IO-Libararies 15 or do i also need the "VXI-pnp-driver" for each instruments? The drivers that are available to download on Agilent-website are from year 2000. Are they still running under the new Vee and XP ? My vee programs are created using panel-drivers. Is this panel driver a part of the installed VXI-pnp-driver? Thanks for some information. |
2个回答
您应该只需要VEE和IO库,显然包括VXI支持。
pnp驱动程序是面板驱动程序的替代品(我确信这个论坛上有几个可以详细说明为什么HP /安捷伦远离面板驱动程序......)因此您不需要它们。 您可能会发现大多数(如果不是所有)面板都使用SCPI所需要的是从VEE到VXI总线的通信路径.HTH 以上来自于谷歌翻译 以下为原文 You should only need VEE and the IO Libraries obviously including VXI support. The pnp drivers are an alternative to the panel drivers ( I'm sure there are several on this forum that could give a detailed account of why HP/Agilent went away from panel drivers... ) and so you don't need them. You'll probably find most if not all of your panels use SCPI all that's required is the communication path from VEE to the VXI bus. HTH |
差异面板和pnp驱动程序的任何其他想法?
以上来自于谷歌翻译 以下为原文 any other ideas for difference panel- and pnp-drivers? |
只有小组成员才能发言,加入小组>>
1279 浏览 0 评论
2371 浏览 1 评论
2187 浏览 1 评论
2061 浏览 5 评论
2945 浏览 3 评论
1097浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
747浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
917浏览 0评论
1279浏览 0评论
GMT+8, 2024-12-21 10:31 , Processed in 1.449696 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
