电子发烧友论坛|
亲爱的PSoC开发者
我使用UBFS组件,我编写了程序,我将数据从PC发送到PSoC 3设备(我配置为HID设备),并将相同的数据返回到PC。在PC中,我使用LiBub 1库。我能够连接,但是我不能发送更多的1字节数据,当我试图发送2个字节时,它只发送最后1个字节。是否可以发送更多的1字节,以及如何?我应该更改什么(可能在HID描述符中)?提前感谢Gurgen 以上来自于百度翻译 以下为原文 Dear PSoC Developers I'm using USBFS component and I wrote program that I'm sending data from the PC to the PSoC 3 device (I configured as a HID device) and getting the same data back to the PC. In the PC I'm using Libu*** 1.0 library. I was able to have the connection, but I cannot send more then 1 byte data, when I'm trying to send for example 2 bytes, it only sends the last 1 byte. Is it possible to send more then 1 byte and how? What should I change (maybe in HID descriptors)? Thanks in advance Gurgen |
4个回答
如果你的目的是发送数据和循环,UB-UART是最简单的方法。我不知道利布斯图书馆。你也可以使用Cux.DLL语言来提供Curess。你可以通过“CyControl,exe”来测试PSoC的传输状态,即USB控制中心。
以上来自于百度翻译 以下为原文 If your purpose is just send data and loop back, USB-UART is a most easy way. I don't know about Libu*** library. You can also use CyCUS.dll liblrary that Cupress provided. And you can test transfer-status of PSoC by "CyControl.exe" that is the USB Control Center. |
谢谢你的回答。
是的,我使用了控制中心和UBFS组件,并能够发送更多的1字节和接收。当我把这个类变成HID时,我已经无法使用控制中心,因为发送的数据不活跃。我需要配置PSoC 3作为一个HID设备。我使用LIUBSB,因为它允许在不同的操作系统中使用。 以上来自于百度翻译 以下为原文 Thank you for your answer. Yes I did it using Control Center and USBFS component and was able to send more then 1 byte and recieve. When I changed the class into HID I was already unable to use Control center, because data to sent wasn't active. I need configure PSoC 3 as a HID device. I'm using Libu***, because it's allowed to be used in different operating systems. |
我明白了,它可能与双字节字符Unicode有关吗?我不确定。
以上来自于百度翻译 以下为原文 I see, It might relate with double-byte-charactor, UNICODE ? I'm not sure. |
@哈拉特甘:你能把数据从你的HID设备发送到PC吗?
以上来自于百度翻译 以下为原文 @kharatgn: were u able to send the data more than 1 byte from your HID device to PC ? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 01:49 , Processed in 0.690359 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6833
