我使用同一个应用程序捕捉相机数据使用CYUSB。
但现在我发现,在系统中,WINDOWX XP工作得很好,INT WIN7 32或VistAT系统的丢失数据非常强。 我的应用程序代码是:代码意味着捕获VID大小1280×720,在XP系统中返回数据ALOOST是1280×720, 但在Wi7 32或Vista系统中,它的最大值小于1280×720。我检查司机在W7和Vista是正确的。 顺便说一下,XP系统和Wi7系统Vista安装在同一台PC机上。 有人能帮我吗?谢谢。 DWORE WINAPI CAM线程(空隙* PARAM){CysBeBoint Point=pUSB -& gt;BulkNeNPT;int队列=2;PuCHAR*INVale=新PUCHAR(队列);重叠*INOVLAP =新的重叠[队列];PUCHAR *缓冲器=新PuCHAR(队列);(int i=0;i;lt;队列;I++){INVORC= CREATEAtiON(NULL,FALSE,FALSE,NULL);} PINDEPTP& & GT;TimeOut= 1000;PINDEPTP&GT;StxFelSead(1024×1024);(int i=0;i&lt;QuealSeist;I++)缓冲器 =新的无符号char [1024*1024 ];对于(int i=0;i& lt;QuealSeist;I++)in上下文=PINDEPTP& & BeginDataXfer;(1024×1024,&;iNoVLAP);In i=0;而(My bBead){ PINDEPTP& & Gt;WaitForXfer(&;INOVLAPP[I],1000);PINDEPTP& GT;FinishDataXfer(缓冲器[I],DWBythand,InOVLAPP,InValue);iNeal=PINDEPTP& & GT;BeginDataXfer(缓冲器,1024×1024,和INOVLAPP[I])如果(dWistB==1280×720){pMaMaLaMaReCuNeT+++;} i++;如果(i=队列){i=0;}}返回0;} 以上来自于百度翻译 以下为原文 i use the same application to capture the camera data use cyu***. but now i found that in the system windowx xp it works very well, int win7 32 or vistat system it loss data very strong. my application code is: the code means capture vide size 1280*720 ,in xp system the return data alomost is 1280*720, but in win7 32 or vista system it is alomost less 1280*720. i check the driver in win7 and vista is right. by the way the xp system and win7 system vista is install in the same pc. can any people help me? thanks. DWORD WINAPI Camera_Thread(void *param) { CCyUSBEndPoint* pInEndpt = pUSB->BulkInEndPt; int QueueSize = 2; PUCHAR *inContext = new PUCHAR[QueueSize]; OVERLAPPED *inOvLap = new OVERLAPPED[QueueSize]; PUCHAR *buffers = new PUCHAR[QueueSize]; for (int i=0; i< QueueSize; i++) { inOvLap.hEvent = CreateEvent(NULL, false, false, NULL); } pInEndpt->TimeOut = 1000; pInEndpt->SetXferSize(1024*1024); for(int i=0;i for(int i=0;i LONG dwBytes = 0; int i=0; while(m_bPlaying) { pInEndpt->WaitForXfer(&inOvLap, 1000); pInEndpt->FinishDataXfer(buffers, dwBytes, &inOvLap, inContext); inContext = pInEndpt->BeginDataXfer(buffers,1024*1024,&inOvLap); if(dwBytes==1280*720) { pCameraFrameCount++; } i++; if(i==QueueSize) { i=0; } } return 0; } |
1个回答
你有没有USB跟踪,看看是什么造成数据丢失?
以上来自于百度翻译 以下为原文 Did you take a u*** trace and see what is causing the data loss? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7572浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6120浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7965浏览 2评论
/9
GMT+8, 2025-12-2 18:28 , Processed in 2.524029 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4393
