电子发烧友论坛|
我正在使用LSM9DS0进行设计。
我的目标是将4线SPI连接到MEMs设备。 这是我的界面设计。 我将接口2 SDO引脚的3:1多路复用器添加到MISO中。 我想知道我的方法适合与simgle 4线SPI连接。 如果存在其他想法,请告诉我。 我找不到任何LSM9DS0的参考设计。所以我不能参考任何设计。 ST是否有任何参考设计? #4-wired-spi #interface-confliction#lsm9ds0 #interface 以上来自于谷歌翻译 以下为原文 I'm designing with LSM9DS0. And my goal is interface a 4-wired SPI with the MEMs device. This is my interface design. I add a 3:1 mux for interface 2 SDO pins into a MISO. I want to know that my approach is suitable for interfacing with a simgle 4-wired SPI. If the other idea exist, please let me know. I can't find any reference design for LSM9DS0. So I can't refer any design. Is there any reference design ST proposed? #4-wired-spi #interface-confliction #lsm9ds0 #interface |
4个回答
SDO根据数据表(SPI的标准)排列三态,因此您只需将它们连接在一起即可。使用CS从相应的SDO引脚获取数据。确保它们是独占的,所以没有冲突。这就是我解释数据的方式,以及我将如何使用该部分。
以上来自于谷歌翻译 以下为原文 The SDO lines tri-state according to the data sheets (standard for SPI), so you just connect them together. Use CS to get data from the appropriate SDO pin. Make sure they are exclusive so there is no conflict. That is how I interpret the data, and how I will use the part. |
谢谢ricky,还有一个问题。
如果我使用一个器件作为SPI,那么另一个器件应该是I2C。 由于SCL和SDA信号与SPI和I2C共用,我担心I2C器件有可能被激活。 (LSM9DS0具有I2C从器件功能,从器件的事务通过START信号启动.I2C的START条件定义为SDA从高电平到低电平的转换,而SCL保持高电平.START信号从主器件发送到从器件。) 如果SPI和I2C同时处于活动状态,哪个接口占主导地位? 而且,如何解决这个问题? 我应该通过控制SCLK和SDI的阶段来避免冲突吗? 以上来自于谷歌翻译 以下为原文 Thanks ricky and there is one more question. If I use one device as SPI, then the other device should be I2C. Because the SCL and SDA signal share with the SPI and I2C, I concern about that the I2C device has a possibility of activation. (LSM9DS0 has I2C slave functionality and the transaction of slave is started through a START signal. The START condition of I2C is defined as a HIGH to LOW transition on SDA while the SCL is held HIGH. The START signal transmitted from master to slave.) If the SPI and I2C are active on the same time, Which Interface is dominant? And, How to solve this problem? Should I avoid the confliction by controlling the SCLK and SDI's phase? |
数据手册第6节说如果CS接高电平,则部分为I2C,如果CS为低电平,则为SPI,而CS为低电平时发生的数据事务将为SPI,因此不存在冲突。沟通标准。由于您正在编程主机处理器,因此您可以控制CS和正在使用的prootcol。
以上来自于谷歌翻译 以下为原文 Data sheet section 6 says that if CS is tied high, then part is I2C, if CS is taken low, then it is SPI, and the data transactions that take place while CS is low will be SPI, so there is no conflict between the communication standards. Since you are programming the host processor, you have control of the CS and the prootcol in use. |
但这里有两个CS。我假设CS_G和CS_XM在内部用于选择SPI / I2C(如果CS_G为1且CS_XM为0,则是SPI或I2C模式下的SDA / SDI引脚)?
在同一个SPI总线上,有没有比单个LSM9DS0更多SPI设备的解决方案? 以上来自于谷歌翻译 以下为原文 But here are two CS. I assume CS_G and CS_XM are or'ed internally to select SPI/I2C (If CS_G is 1 and CS_XM is 0, is the SDA/SDI-pin in SPI or I2C mode)? And is there any solution for more SPI-devices than a single LSM9DS0 on the same SPI-bus? |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1468 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1520 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3858 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
747浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
726浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
965浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
766浏览 5评论
/9
GMT+8, 2025-12-11 05:11 , Processed in 0.932133 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1168
