电子发烧友论坛|
你好
我已经使用spartan 6(xcs6lx75)定制了一个新板,但是当我尝试通过jtag接口配置它时,screeen上有错误。 我想知道在将配置引脚连接到错误的级别时是否有错误的想法。 因此我想知道,如果我想配置斯巴达6,我需要注意多少针? 他们是什么? 以上来自于谷歌翻译 以下为原文 Hello I have customized a new board with spartan 6(xcs6lx75), however, there is error on screeen when I try to configure it by jtag interface. I wonder whether I got a wrong idea when connecting configuration pin to the wrong level. Thus I want to know, if I want to configure spartan 6, how many pins do I have to be careful with? what are them? |
9个回答
y,JTAG优先于所有模式:它“接管”配置引擎。看起来电缆没有连接,或者它没有供电。
检查所有连接,电压等 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 y, JTAG takes precedence over all modes: it "takes over" the configuration engine. It looks like the cable is not connected, or it is not powered. Check all the connections, voltages, etc. Austin Lesea Principal Engineer Xilinx San Jose |
增加奥斯汀的建议:我相信如果PROG_B引脚保持低电平(置位),JTAG不起作用。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 JTAG takes precedence over all modes: it "takes over" the configuration engine. Adding to Austin's advice: I believe that JTAG does not work if PROG_B pin is held LOW (asserted). -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
除PROG_B外,还需要配置所需的所有电源电压。
也 如果您打算使用间接编程编程连接到S6的SPI闪存,那么您 必须在模式引脚上设置正确的SPI主配置。 我会建议 查看“Spartan 6配置用户指南”中推荐的电路。 我会 建议至少在INIT_B和DONE引脚上放置上拉电阻。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 In addition to PROG_B, you need all of the supply voltages required for configuration. Also if you intend to program a SPI flash attached to the S6 using indirect programming, then you must have the correct setting on Mode pins for SPI master configuration. I would suggest looking at the recommended circuits in the Spartan 6 Configuration User Guide. I would recommend at the least placing pullup resistors on INIT_B and DONE pins as well. -- Gabor -- Gabor |
我粘贴我的schmatic。
你能帮我检查一下吗? 以上来自于谷歌翻译 以下为原文 I paste my schmatic. could you please help me check it? |
原理图问题:
1.删除RP11。 2. JTAG接头P1的引脚排列与Xilinx或Digilent JTAG编程电缆不匹配。 3.用0欧姆电阻(或焊点)替换R534。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Schematic problems: 1. Remove RP11. 2. The JTAG header, P1, has a pinout which does not match Xilinx or Digilent JTAG programming cables. 3. Replace R534 with 0 ohm resistor (or blob of solder). -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
你好!在尝试jtag配置时,将vfs和vbatt连接到地面是否至关重要?
以上来自于谷歌翻译 以下为原文 hello! is it crucial for me to connect vfs and vbatt to the ground when trying jtag configuration? |
根据UG380:
VFS :(如果没有编程eFUSE)VCC,GND或未连接。 推荐:GND VBATT :(如果不使用AES加密)VCCAUX,GND或未连接。 推荐:GND 如果仔细查看UG380,两个引脚的建议都存在冲突。 我打开了一个网页来清理它。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 According to UG380: VFS: (if not programming eFUSE) VCC, GND, or unconnected. recommended: GND VBATT: (if not using AES encryption) VCCAUX, GND, or unconnected. recommended: GND If you look carefully through UG380, there are conflicting recommendations for both pins. I have opened a webcase to clean this up. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 06:44 , Processed in 0.975629 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2177
