你好!
我对斯巴达6模具中的gclk引脚有一些疑问。 我想将频率从FPGA输出到外部板。 我知道gclk引脚是专用时钟引脚,它们直接连接到bufg。 我尝试在fpga pll的帮助下合成必要的频率并通过gclk输出,但是ISE产生了错误。 ISE提供使用ODDR2组件。 我应用了这个建议。 但是,如果我使用这种方法,我可以使用gpio引脚,它们将像gclk一样,如果comparisoncriteria是信号质量,则偏斜。 我对吗? 我假设GCLK引脚只能作为输入直接连接到全局时钟网络。 谢谢! 以上来自于谷歌翻译 以下为原文 Hello! I have some questions about gclk pins in spartan 6 die. I want to output frequency from fpga to external board. I know that gclk pins is dedicated clock pins and they directly connected to bufg. I tried to synthesis necessary frequency with a help of fpga pll and output it through gclk, but ISE generated error. ISE offered to use ODDR2 component. I applied this suggestion. But if i use such method I can use gpio pins and they will be the same like gclk, if comparison criteria is signal's quality, skew. Am I right? And I assume that GCLK pins can directly attach to global clock net only as inputs. Thank you! |
3个回答
GCLK引脚是多功能引脚而非专用引脚。
它们也可以用作输入和输出的普通IO。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 GCLK pins are multifunction pins not dedicated pins. They can also be used as normal IO for inputs and outputs.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
为了澄清mcgett的评论,时钟输出使用标准DDR输出触发器(ODDR2)
存在于任何IOB中(但如果您使用的是工程样本,请小心阅读勘误表 硅)。 因此,使用GCLK引脚作为输出不会带来任何好处。 唯一的优势 对于GCLK引脚,是提供较低的BUFG或DCM输入的专用路径 时钟插入延迟。 因此,您应该使用GCLK引脚作为时钟输入,但任何IO引脚 与其他任何时钟输出一样好。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 Just to clarify mcgett's comments, clock output uses a standard DDR output flop (ODDR2) which exists in any IOB (but be careful to read errata if you're using Engineering Sample silicon). So you don't get any benefit using a GCLK pin as an output. The only advantage for GCLK pins is the dedicated route to the input of a BUFG or DCM that offers lower clock insertion delay. So you should use a GCLK pin for clock inputs, but any IO pin is as good as any other for clock outputs. -- Gabor -- Gabor |
只有小组成员才能发言,加入小组>>
2337 浏览 7 评论
2756 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2229 浏览 9 评论
3306 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2383 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
692浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
489浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
270浏览 1评论
698浏览 0评论
1893浏览 0评论
GMT+8, 2024-10-18 18:54 , Processed in 1.339364 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
