尊敬的先生/女士
应用注意事项-AN7665 PSOC®1汽车超声波测距仪 在上面提到的应用笔记中,在第13页,Power Jack有一个连接。 我只是想知道什么输入不受控制的电压会给这个电源插座。 并且它将是直流或交流。 等待同样的解决方案 当做 电源插座 148.1 K 以上来自于百度翻译 以下为原文 Dear Sir/madam Application Note - AN76530 Heading - PSoC® 1 Automotive Ultrasonic Distance Measurement In the above mentioned application note, on page no - 13, there is a connection for the Power Jack . I just wanted to know that what Input unregulated voltage would be given to this power jack. and wether it would be DC or Ac . Waiting for your solution regarding the same Regards
3个回答
看起来名义上是12 V马克斯的调节器是26 V,但这可能超过Tj
负载调节器。你需要计算负载电流,并进行热分析。 以确保您不超过TJ,即使它有内部热保护 短路能力。 问候,Dana。 以上来自于百度翻译 以下为原文 Looks like nominal is 12 V. Max for regulator is 26 V, but that probably exceeds Tj for the regulator under load. You need to calculate load current, and do the thermal analysis to make sure you do not exceed Tj, even though it does have internal thermal protection and short circuit capability. Regards, Dana. |
在AN765 30中所示的电源电路提供连接3个电源之一——电池(VBAT)、从直流适配器(PWR千斤顶)供电和来自另一个电路(VIN)的电压。如果您使用的是单个源,则不必连接D6和D5。
你可以使用一个12V的电池或者建立一个不受控制的电源(~12V)(降压变压器-GT;桥式整流器)。对于5V稳压器,可以使用最常用的IC LM7805。 以上来自于百度翻译 以下为原文 The power circuit shown in AN76530 provides provision to connect one of 3 sources -battery (VBAT), supply from DC adapter (PWR JACK) and voltage from another circuit (VIN). If you are using a single source, you don't have to connect D6 and D5. You can either use a battery of 12V or build a unregulated power supply (~12V) (step down transformer -> bridge rectifier). For 5V regulator, you can use most commonly available IC LM7805. |
作为汽车应用的一个更大的挑战是处理问题。
负载转储瞬变,AP注记未处理,也不AP AP 电源电路在这方面是适当的。 En.WiKiTo.Org/Wik/Load转储 www. Ti.COM/GANALAL/DOCS/LIT/GETMICROATURU.TSP 问候,Dana。 以上来自于百度翻译 以下为原文 One of the bigger challenges, being an automotive application, is handling load dump transients, which the ap note does not address, nor is the ap note power supply circuit adequate in this regard. en.wikipedia.org/wiki/Load_dump www.ti.com/general/docs/lit/getliterature.tsp Regards, Dana. |
只有小组成员才能发言,加入小组>>
745个成员聚集在这个小组
加入小组2024 浏览 1 评论
1782 浏览 1 评论
3586 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1715 浏览 6 评论
1481 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
419浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
296浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
375浏览 2评论
318浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
532浏览 2评论
GMT+8, 2024-10-14 12:32 , Processed in 0.658536 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
