电子发烧友论坛|
你能告诉我如何在PSoC创建者中使用PSoC测量电压的光强度。
帮助我与样本代码和设计。 以上来自于百度翻译 以下为原文 can u plz suggest me how can i measure light intensity in terms of voltage using PSoC in PSoC creator. help me out with sample code and design. |
5个回答
有很多方法。你可以使用一个光电晶体管、二极管或电阻器和一个ADC。您可以使用数字光传感器,然后通过I2C或SPI连接到PSoC。
我们在说什么传感器? 以上来自于百度翻译 以下为原文 There are many methods. You can use a photo transistor, diode or resistor together with an ADC. You can use a digital light sensor, which then gets connected via I2C or SPI to the PSoC. What sensor are we talking about? |
我计划利用光到频率转换器TSL255。帮我解决这个问题…也帮助我,如果我去光电二极管。
以上来自于百度翻译 以下为原文 i m planning to make use of light to frequency converter TSL235. help me out with this one also...and also help me if i'll go with photodiode. |
首先,在你开始任何经验之前,你应该给出一些结论。
测量范围 准确度 噪声滤光(萤光灯) 处理(ButtoBS,开关,范围选择) 显示(黑暗中的雷丁)????冻结按钮 作为提示:这些是你的仪表的规格,把它们写下来,将有助于你保持跟踪。 鲍勃 以上来自于百度翻译 以下为原文 First, before you start any experiences, you ought to give some thougts into Range of measurements Accuracy Noise filtering (Flourescent lamps) Handling (Buttobs, switches, range select) Display (reding in the dark??? Freeze button) As a hint: These are the specs of your meter, write them down, will help you to keep track Bob |
您已经在另一个线程中问了这些问题(HTTP://www. CyPress)COM/?APP =论坛和ID;ID=1573和;RID=55337),并得到了一些答案。你需要做频率测量,正如已经解释过的那样。你还有其他问题吗?如果是这样,请询问他们,以便我们回答他们。或者你希望这些家伙能拿出你现成的解决方案吗?
以上来自于百度翻译 以下为原文 You already asked these question in another thread (http://www.cypress.com/?app=forum&id=1573&rID=55337 ) and got some answers. You need to do frequency measurement, as already explained there. Do you have any additional questions? If so, please ask them so we can answer them. Or do you expect the guys here to come up with you ready-made solution? |
Bob Marlowe:我设计这个的因素取决于频率的准确度和可见光谱范围。
以上来自于百度翻译 以下为原文 Bob Marlowe: my factor for designing this depends on accuracy and visible spectrum range of frequency. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 06:00 , Processed in 0.766937 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1822
