电子发烧友论坛|
我有斯巴达3 FPGA套件。
我使用xilinx ise 10.1生成了.bit文件,现在尝试将其下载到套件中。 当我运行xilinx Impact时,它会显示电缆错误,如下所示。 检查电缆驱动程序。驱动程序windrvr6.sys版本= 8.1.1.0。 WinDriver v8.11 Jungo(c)1997 - 2006 Build Date:Oct 16 2006 X86 32bit SYS 12:35:07,version = 811.LPT base address = 0378h.ECP base address = 0778h.Cable connection established.ECP port test failed 。 在兼容模式下使用下载电缆。 从帮助我开始知道在fileset.txt文件中应该出现以下行。 :: summary =并行电缆驱动程序 我的fileset.txt在C: Xilinx 10.1 ISE文件夹中没有此行。 内容如下。 Thu Feb 03 16:58:35 TZ 2011 :: product = ISEThu Feb 03 16:58:35 TZ 2011 :: configuration = FoundationThu Feb 03 16:58:35 TZ 2011 :: version = 10.1Thu Feb 03 16:58: 35 TZ 2011 :: Registration_ID = 1AN2AMZ5JHJXSA9EXZTK431J1Thu Feb 03 16:58:35 TZ 2011 :: summary =位置:C: Xilinx 10.1 ISEThu Feb 03 16:58:35 TZ 2011 :: summary =设计环境ToolsThu Feb 03 16 :58:35 TZ 2011 :: summary =除Virtex4和Virtex5外的所有FPGA器件 BIOS菜单中的并行端口设置为ECP模式并启用。 请为我的问题建议任何解决方案。 请告诉我,我怎么知道我的FPGA是否损坏。 问候。 Devashish。 以上来自于谷歌翻译 以下为原文 I have spartan 3 fpga kit. I have generated the .bit file using xilinx ise 10.1 and now trying to download it to the kit. As I run xilinx Impact it shows me cable error, as follows. Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811. LPT base address = 0378h. ECP base address = 0778h. Cable connection established. ECP port test failed. Using download cable in compatibility mode. From the help I came to know that in the fileset.txt file following line should be present. |
5个回答
它与甚至与FPGA交互的地方还远远不够。
如果芯片损坏,你还不知道(它不会导致这个错误,我不认为)。 除非你有其他理由怀疑FPGA已经死了,否则我怀疑它是否已损坏。 至于你的电缆错误,我首先检查设备管理器并确保端口至少在Windows中正确显示。 我对旧的并行电缆没有太多经验 - 我通常使用USB平台电缆。 以上来自于谷歌翻译 以下为原文 It isn't getting far enough to where it is even interacting with your FPGA. If the chip is damaged, you wouldn't yet know (and it wouldn't cause this error I don't think). Unless you have another reason to suspect the FPGA is dead, I doubt it is damaged. As for your cable error, I'd start by checking device manager and making sure the port at least shows up in Windows correctly. I've not got a lot of experience with the older parallel cables--I usually use the USB platform cable instead. |
particle写道:
至于你的电缆错误,我首先检查设备管理器并确保端口至少在Windows中正确显示。 我对旧的并行电缆没有太多经验 - 我通常使用USB平台电缆。 谢谢粒子的回复。 我已经检查了设备管理器设置。 并行端口工作正常。 以上来自于谷歌翻译 以下为原文 particle wrote: Thank you Particle for your response. I have already checked the device manager settings. The parallel port works fine. |
感谢Gabor的回复。
gszakacs写道: 我的fileset.txt for 10.1does也没有这条线,我可以在我的系统上使用Parallel Cable IV。 它更可能是BIOS设置或可能是电缆驱动程序的问题 建立。 我认为有一种方法可以告诉驱动程序您的LPT端口的ECP地址。 我建议在这些论坛中搜索“ECP”,看看你是否能找到解决方案。 - Gabor 很高兴知道你的fileset.txt也没有这行。 所以我可以假设我的安装是正确的。 但我也检查了BIOS设置。 我在ECP模式下启用了并行电缆端口。 正如我在问题中所示,影响也会获得ECP端口地址。 我现在正在寻找其他论坛以及您的建议。 如果您有任何更好的想法,请与我分享。 以上来自于谷歌翻译 以下为原文 Thank you Gabor for your response. gszakacs wrote:My fileset.txt for 10.1does not have the line either and I can use the Parallel Cable IV on my system.It is more likely to be a problem with the BIOS setup or possibly the cable driver It is good to know that your fileset.txt does not have the line either. So I can assume that my installation is correct. But I have also checked the BIOS set up. I have enabled the parallel cable port in ECP mode. The impact gets the ECP port address as well, as i have shown in the question. I am now looking for other forums as well as per your suggestion. If you get any better idea then please share it with me. |
编程说明:此线程正在此处继续。
- 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Programming note: this thread is being continued here. - Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 02:53 , Processed in 0.802107 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1031
