电子发烧友论坛|
我想在DPM中运行。我使用SPC5Studio创建.wsx配置进行调试,但是当我尝试连接到目标时出现以下故障:
-------------------------------------------------- -------- 连接失败报告来自 基本UDE目标接口,版本:1.14.2 创建时间:02/19 / 18,16:01:11 ------------------------------------- --------------------- Windows版本: Win8() 管理员:yesUDE版本: 发布:4.08.02 建立:8012 路径:C: Program Files(x86) pls UDE Starterkit 4.8目标配置文件: C: WORK_DRIVE PROJECTS U1713 MDL -1 CONFIGURAtiON -03 DEVELOPMENT .ude .target stm_spc56xl_spc56el70_discovery_starterkit_dp_debug_jtag.cfgError消息: PpcJtagTargIntf:无法连接目标! PpcJtagTargIntf:使用DPM配置时未检测到目标上的双处理器模式! PpcJtagTargIntf:无法停止处理器!设置: PortType:CommDev CommDevSel:PortType = USB,Type = FTDI [参见整个日志的附件] 我可以在LSM中连接和调试就好了。 以上来自于谷歌翻译 以下为原文 I am wanting to run in DPM . I use SPC5Studio to create a .wsx configuration to debug with, but I get the following failure when I try to connect to the target: ---------------------------------------------------------- Connection Failed Report from Basic UDE Target Interface, Version: 1.14.2 created: 02/19/18, 16:01:11---------------------------------------------------------- Windows version: Win8 () Admin: yesUDE version: Release: 4.08.02 Build: 8012 Path: C:Program Files (x86)plsUDE Starterkit 4.8Target configuration file: C:WORK_DRIVEPROJECTSU1713MDL-1 CONFIGURATION-03 DEVELOPMENT.ude.targetstm_spc56xl_spc56el70_discovery_starterkit_dp_debug_jtag.cfgError messages: PpcJtagTargIntf: Can't connect target ! PpcJtagTargIntf: No Dual Processor mode on target detected when using DPM configuration ! PpcJtagTargIntf: Failed to halt processor !Settings: PortType: CommDev CommDevSel: PortType=USB,Type=FTDI[see attachment for whole log] I can connect and debug in LSM just fine. |
9个回答
我得到的短暂错误是
&LT;&LT; 来自组件'PpcJtagTargIntf'的消息: 无法连接目标!来自组件'PpcJtagTargIntf'的消息: 使用DPM配置时未检测到目标上的双处理器模式!来自组件'PpcJtagTargIntf'的消息: 处理器处于WAIT状态!来自组件'PpcJtagTargIntf'的消息: 无法停止处理器!&gt;&gt; 以上来自于谷歌翻译 以下为原文 The short error I get is << Message from component 'PpcJtagTargIntf' : Can't connect target !Message from component 'PpcJtagTargIntf' : No Dual Processor mode on target detected when using DPM configuration !Message from component 'PpcJtagTargIntf' : Processor is in WAIT state !Message from component 'PpcJtagTargIntf' : Failed to halt processor !>> |
马修你好,
我从未使用PLS UDE 4.8测试过DPM配置 我问应用团队。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Matthew , I have never tested DPM Configuration with PLS UDE 4.8 I am asking to the application team. Best regards Erwan |
马修你好,
必须通过闪存阴影块中的LSM_DPM用户选项位启用DPM 记忆。有关详细信息,请参阅SPC56EL参考手册。 我正在联系PLS支持部门如何通过PLS USB / JTAG实现这一目标。 在附件中,示例如何使用TRACE32启用DPM 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Matthew , It is mandatory to enable the DPM through the LSM_DPM user option bit in the shadow block of the flash memory. For more details, please, refer to the SPC56EL Reference Manuals. I am contacting PLS Support how to do that by PLS USB/JTAG. In attachment, an example how to enable DPM with TRACE32 Best regards Erwan |
马修你好,
是的,它应该工作,但你需要P&amp; E调试器的东西来做到这一点。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Matthew , Yes , it should work , but you need P&E Debugger stuff to do that. Best regards Erwan |
复位时是否有'执行初始化命令'会设置该寄存器?我是第一个使用PLS解耦的SPC56吗?
以上来自于谷歌翻译 以下为原文 Is there an 'Execute Initialization Commands on reset' that would set this register? Am I the first to use the SPC56 decoupled, with PLS? |
马修你好,
关于PLS方面有常见问题 https://www.pls-mc.com/microcontroller-faqs/faqs-a-1291.html?sh8=bHNt 经过我们的应用团队测试和验证。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Matthew , There is FAQ on PLS side https://www.pls-mc.com/microcontroller-faqs/faqs-a-1291.html?sh8=bHNt Tested and Validated by our Application team. Best regards Erwan |
很难找到SPC5Studio的MemTool插件或者PLS-UDE的插件。
以上来自于谷歌翻译 以下为原文 Having a pretty tough time finding either a MemTool plugin for SPC5Studio, or the addin for PLS-UDE. |
我认为问题是PLS-UDE网站有点重新安排,我会联系他们。 Erwan,请保持精彩的工作。
以上来自于谷歌翻译 以下为原文 I think the issue is the PLS-UDE website is a bit re-arranged and I will contact them. Erwan, please keep up the fantastic work. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1447 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1494 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3641 浏览 1 评论
3834 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2454 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
744浏览 5评论
/9
GMT+8, 2025-12-1 18:16 , Processed in 1.028140 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1910
