电子发烧友论坛|
安捷伦,我一直在研究最初在Vee 6.0中创建的旧程序,现在尝试在7.5或更高版本的运行时运行,并且已经遇到配置错误。
当程序开始并且试图使用任何一个仪器面板时会弹出一个配置错误:找不到“RF_Gen”的驱动程序。 RF_Gen是手动标识符。 它说它想要ID文件名hp8647_8.cid,我在C: program files agilent agilent vee runtime x.x中添加到运行时的ids文件夹中。在开发环境中运行时没有问题。 检查驱动程序是否位于其他位置。 不知道为什么我遇到这个问题。 任何帮助都会很棒。 以上来自于谷歌翻译 以下为原文 Agilent, I have been working on an old program created originally in Vee 6.0 and now trying to run on runtimes of 7.5 or newer and have been running into and issue with a configuration error. When the program begins and trys to use any of the intrument panels is pops up with a configuration error: Driver for "RF_Gen" not found. RF_Gen being the manual identifier. It is saying that it wants ID filename hp8647_8.cid which i added to the ids folder of the runtime in the C:program filesagilentagilent vee runtime x.x When running in the development environment there is no problem. checked that the driver is not located in another location. not sure why i am running into this issue. any help would be great. 附件
1个回答
转到开始>程序> Agilent VEE Pro xx RunTime Config并启动IO配置。
添加程序中使用的仪器,使用相同的名称,并设置面板驱动程序文件。 这应该解决我希望的问题:)希望这有帮助, - mk 以上来自于谷歌翻译 以下为原文 Go to Start > Programs > Agilent VEE Pro xx RunTime Config and launch IO Configuration. Add the instrument used in the program there, with the same name and also set the Panel Driver file. This should fix the problem I hope :) Hope this helps, - mk |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 23:06 , Processed in 0.614924 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1523
