当使用模拟器调试似乎在实际目标上工作的代码时,我收到以下错误。 ''在0x801处停止写保护''芯片是stm8s105c6,代码是用C使用Raisonnance编译器编写的。我查看了STVD内部的帮助,它提到了在MCU配置下查看内存映射,但我似乎找不到这个对话框,也没有提到如何导航到这个对话框。还有其他人遇到过这个问题吗?任何人都可以帮我解决这个问题吗?谢谢
#STVD写保护模拟器 以上来自于谷歌翻译 以下为原文 I am getting the following error when using the simulator to debug code that seems to be working on the actual target. '' stopped on write protection at 0x801'' The chip is stm8s105c6 and code is written in C using Raisonnance compiler. I looked at help inside STVD and it mentions looking at the memory mapping under MCU configuration but I cannot seem to locate this dialog and there is no mention on how to navigate to this dialog. Has anyone else encountered this problem? Can anyone help me to solve this issue? Thanks #stvd-write-protection-simulator |
1个回答
你好迈克尔!
stm8s105c6 RAM映射到地址0x0 - 0x7FF,因此0x801是无效的RAM地址。 当模拟器运行您的代码时,它会在访问未定义的RAM位置时停止。 发生这种情况时,反汇编窗口中会突出显示导致错误的指令。 ''real''stm8s105c6不检查指令是读取还是写入保留的RAM位置。 如果代码在''真实''stm8s105c6上运行,它可能仍然包含错误,如您所示。 模拟器是一个功能强大的调试工具,因此我建议尽可能多地使用它来发现一些可能隐藏在某处的错误,并在截止日期到期时显示... 问候, EtaPhi 以上来自于谷歌翻译 以下为原文 Hello Michael! stm8s105c6 RAM is mapped at addresses 0x0 - 0x7FF, so 0x801 is an invalid RAM address. When the simulator is running your code, it therefore stops when it access an undefined RAM location. When this happens, the instruction that caused the error is highlighted in the disassembler window. A ''real'' stm8s105c6 doesn't check if an instruction reads or writes a reserved RAM location. If a code runs on a ''real'' stm8s105c6, it may still contain errors as your case shows. The simulator is a powerful debug tool, so I suggest to use it as much as possible to discover some bugs that may conceal themselves somewhere and show up when a deadline is expiring... Regards, EtaPhi |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2413 浏览 1 评论
3129 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1698 浏览 1 评论
3511 浏览 6 评论
5867 浏览 21 评论
859浏览 4评论
1234浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
503浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1216浏览 3评论
1271浏览 3评论
GMT+8, 2024-9-21 08:56 , Processed in 1.123884 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
