嗨大家好,每当我尝试运行vee运行时间来测试一个单元时,我得到“配置错误:串行接口,在10,没有为此系统配置错误号码:801请参阅安装手册中的说明在交易号:1
对象标题:多仪器直接I / O对象类型:多仪器直接I / O在UserFunction中:CloseDUT“它只是错误地连接设备或只是我的vee.io文件配置不正确。 p.s这台电脑最近已经升级到Windows 7,并且所有可用的配置都是在windows xp PC上完成的。 同样在Windows 7上使用vee pro运行时9.3 PCEdited:TechMonkey于2012年11月5日上午10:55 以上来自于谷歌翻译 以下为原文 Hi Guys, Every time i try to run vee run time to test a unit i get “Configuration error: Serial interface, at 10, is not configured for this system Error number: 801 Refer to the installation manual for instructions In Transaction number: 1 Object title: Multinstrument Direct I/O Object type: Multinstrument Direct I/O In UserFunction: CloseDUT” is it just attaching the device incorrectly or just my vee.io file is not configured correctly. p.s this pc has been recently upgraded to windows 7 and all of the pervious configuration was done on a windows xp PC. Also using vee pro runtime 9.3 on the windows 7 PC Edited by: TechMonkey on Nov 5, 2012 10:55 AM |
1个回答
简单的问题:你的Windows 7 PC还有串口COM10吗?
如果没有,那么您需要在VEE运行时配置中添加一个“not live”。 然后你应该能够打开你的VEE程序,它可能动态地设置端口地址。 通常我有一些'虚拟'地址,例如Ser_Dev作为非现场串行设备,Gpib_Dev作为非现场GPIB设备等等,用于设置程序与仪器,然后在运行时设置真实地址 使用Scope1等别名链接到工作站/ PC上的实时地址。 HTH,Mike Watts 以上来自于谷歌翻译 以下为原文 Simple question: does your Windows 7 PC still have a serial port COM10? If not then you'll need to add one in your VEE runtime config as 'not live'. Then you should be able to open your VEE program which presumably sets the port address dynamically. Typically I have a few 'dummy' addresses such as Ser_Dev as a non-live serial device, Gpib_Dev as a non-live GPIB device and so on used for setting up programs with instruments and then the real address is set up at run-time using an alias such as Scope1 which is linked to a live address on the workstation / PC. HTH, Mike Watts |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 23:55 , Processed in 0.419665 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1265
