电子发烧友论坛|
大家好,它来自测试仪器。
我试图在我的各种8560a单位中重新调整我的yto,因为如果安装了跟踪代码,8560a服务指南中的说明是不正确的。 没有办法选择ext mixer,并且辅助控制菜单中没有外部混音器软键。 一旦安装了跟踪gen,它就会被删除。 那么如何重新调整或检查我的yto? 我唯一能想到的就是以某种方式对单元进行解编程,使其认为没有安装跟踪代。 然后直接将y输出从yto输入到我的计数器? 或者将它路由到正常路由的路由器? 我很难过请有人告诉我如何做到这一点,我也想知道分析仪是如何知道安装了跟踪代码的。 是一个软件程序还是只是在向9系列添加opts时的跳线? 谢谢 ! 以上来自于谷歌翻译 以下为原文 Hi everyone its paul from test cal instruments. I have tried to realign my yto in my various 8560a units and cant because the instructions in the 8560a service guide are incorrect if a tracking gen is installed. there is no way to select ext mixer unpre, and there is no external mixer softkey in the aux control menu. it is removed once tracking gen is installed. so how do I realign or check my yto? the only thing i can think of is somehow deprogramming the unit to making it think there is no tracking gen installed on it. and then taking the lo output directly from the yto feed to my counter? or routing it into the lo dist amp as it would have been normally routed? im stumped can someone please tell me how to do this and also I would like to know how the analyzer knows there is a tracking gen installed. is that a software program or just a jumper like when adding opts to the 9 series? thanks ! |
3个回答
保罗,简称收购HP 85629B(测试和调整模块)TAM。
它插入大容量存储器模块所在的后连接器。 它有程序没有或没有选项002。 以上来自于谷歌翻译 以下为原文 Paul, Acquire a HP 85629B (Test and Adjustment Module) TAM for short. It plugs into the back connector where the mass memory module goes. It has the procedure there w/ or w/o Option 002. |
谢谢,但我发现8560a服务手册有一个关于它的手动程序与opt 002。 以上来自于谷歌翻译 以下为原文 thanks but I found the 8560a service manual has a manual procedure about it with opt 002. |
我也有完全一样的问题。
请问你能分享设置顺序吗? 谢谢。 以上来自于谷歌翻译 以下为原文 I have exactly the same problem. Please can you share the setup sequence? Thanks. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 01:12 , Processed in 1.553925 second(s), Total 48, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1161
