电子发烧友论坛|
似乎没有单独的LCR论坛部分,但之前的帖子表明该论坛将是适当的位置。
我在使用U1732C仪表时发现了两个不同的问题。 当仪表处于公差模式时,它会精确计算百分比,但如果读数在公差范围内(一声嘟嘟声)或不响(三声嘟嘟声),则不会发出蜂鸣声。 在设置中启用蜂鸣声,蜂鸣声可用于仪表上的其他功能。 选择哪种公差百分比没有任何区别。 它不是一个showstopper,但让这个工作很好。 第二个问题是Max / Min / Avg功能只存储一个读数。 仪表处于手动模式,读数稳定,无过载读数。 我完全遵循了用户指南说明,并尝试了其他键入组合,但没有运气。 我查看了固件历史记录,似乎没有任何参考这些问题作为可能的固件更新。 我不知道我的仪表是什么固件版本。 似乎没有办法找到这个,因为仪表在启动时没有显示它,并且无法在设置/配置菜单中显示。 有没有人有什么建议? 以上来自于谷歌翻译 以下为原文 There does not appear to be a separate LCR forum section but a previous post had indicated that this forum would be the appropriate location. I have found two different issues while using the U1732C meter. When the meter is in tolerance mode, it calculates the percentages fine but will not beep if the reading is within the tolerance range (one beep) or not (three beeps). The beep is enabled in the setup and the beep does work for other functions on the meter. It does not make any difference which tolerance percenatage is chosen. It's not a showstopper, but it would be nice to have this working. The second issue is that the Max/Min/Avg function will only store one reading. The meter is in manual mode and the readings are stable and there is no overload reading. I followed the User Guide instructions exactly and also tried other key entry combinations, but no luck. I looked at the firmware history and there does not seem to be any reference to either of these issues as a possible firmware update. I don't know what firmware version my meter is at. There does not seem to be a way to find this out as the meter does not show it on startup and is not available to display in the setup/configuration menus. Does anyone have any suggestions? |
3个回答
我有完全相同的问题,U1733C。
我想这是一个固件问题(我的固件是00.24,比网站上这个日期最新的FW可用性更新,这是00.21)。 如果在打开之前显示FW版本,则按住Ai键。 编辑:nicu于2012年12月5日上午2:28编辑:nicu于2012年12月5日上午2:31 以上来自于谷歌翻译 以下为原文 I have exactly the same issue, with an U1733C. I suppose it is an firmware issue (my firmware is 00.24, newer than the latest FW availabe at this date on the web site, which is 00.21). The FW version if displayed if before turning on you keep pressed the Ai key. Edited by: nicu on Dec 5, 2012 2:28 AM Edited by: nicu on Dec 5, 2012 2:31 AM |
huangshouda 发表于 2019-5-15 19:50 谢谢你的回复nicu。 我检查了我的固件,它是00.20。 希望安捷伦将花费一些时间并提供固件修复程序。 总的来说,我非常喜欢这个装置,但是不希望安捷伦设备出现这些问题。 以上来自于谷歌翻译 以下为原文 Thanks for the reply nicu. I checked my firmware and it was 00.20. Hopefully Agilent will spend a bit of time and come out with a firmware fix. Overall I really like the unit, but did not expect to see these kinds of issues with an Agilent device. |
这些已在新固件v00.25中修复,您可以在下面的链接中下载最新固件。
http://www.home.agilent.com/agilent/software.jspx?ckey=1554854&lc=eng&cc=US&nid=-11143.0.00&id=1554854 以上来自于谷歌翻译 以下为原文 These have been fixed in the new firmware v00.25, you may download the latest firmware in the link below. http://www.home.agilent.com/agilent/software.jspx?ckey=1554854&lc=eng&cc=US&nid=-11143.0.00&id=1554854 |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 01:59 , Processed in 3.069977 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2227
