大家好,我的ICD3有个奇怪的问题。就在一个星期前,它停止工作了。我做的第一件事是用AC164113模块对程序员进行自我检查,报告了一个问题:所以,我打开了客户支持的票来解决这个问题。他们转向SAR并给我一个替代品,今天收到了。首先,我把它插进去,猜猜怎么回事,用同样的错误信息仍然是错误的。所以,我尝试了一个不同的USB电缆,没有用。-尝试用MPLAB-X 3.51空白检查两个干净的PIC16F818:返回ID错误(0)。在PIC16F818上用MPLAB-X IPE尝试同样的事情:与ABO相同。在不同的PC上移动和重复上面的所有内容:没有变化。-在同一台不同的PC上,用MPLAB 8重试:没有改变。OS是两个PC上的Windows 7 X64。尝试重新安装Java和MPLAB-X,这两个版本都是不同的版本。实际上我没有选择。我希望这里的人能知道发生了什么事,我等待客户支持的答复。
以上来自于百度翻译 以下为原文 Hello everyone. I've got a weird problem with my ICD3. Just out of the blue, a week ago it stopped working. First thing I did was to self-check the programmer with the AC164113 module, which reported a problem: Test interface PGC clock line write failure. Please ensure that the tester is properly connected. Test interface PGD data line write not tested. Test interface PGC clock line read not tested. Test interface PGD data line read not tested. Test interface LVP control line not tested. Test interface MCLR level not tested. Interface test could not be completed. Please contact your local FAE/CAE to SAR the unit. So, I opened a ticket with customer support to solve the issue. They turned to SAR and sent me a replacement, received today. First thing, I plug it in and, guess what, still faulty with the same error message. So, I: - Tried with a different USB cable, to no avail. - Tried blank checking a couple of clean PIC16F818 with MPLAB-X 3.51: returned ID error (0). - Tried the same thing on the PIC16F818 with MPLAB-X IPE: same as above. - Move and repeat all of the above on a different PC: no change. - On the same different PC, retry all with MPLAB 8: no change. OS is Windows 7 x64 on both PC. Tried reinstalling Java and MPLAB-X, different versions of both. I'm actually out of options. I hope someone here may have an idea of what's going on, while I wait for an answer from customer support. Thanks in advance Paul |
5个回答
进一步的信息:尝试用XP在VM上安装MPLAB-X新安装。同样的结果,测试失败…
以上来自于百度翻译 以下为原文 Further info: tried a MPLAB-X fresh install on a VM with XP. Same result, test failed... sad: |
HiDID更换了一个新的目标电缆(短的一个6P6C连接器)?我会开始在那里寻找问题。
以上来自于百度翻译 以下为原文 Hi Did the replacement come with a new target cable (the short one with the 6P6C connectors)? I would start looking for the problem there. Best regards Jorge |
不,我在用旧的,但是我用RJ电缆检查器测试了,看起来还行。
以上来自于百度翻译 以下为原文 No, I'm using the old one, but I tested it with a RJ cable checker and seems ok... |
您好,你们有没有原始的微芯片板(已知的工作板)?如果你有一个替代品,它不工作,这是一个很可能的工具不是问题…所以接下来要检查的是应用板和PC安装(尝试安装MPLAB X在另一台PC上)。
以上来自于百度翻译 以下为原文 Hi, Do you have any original Microchip board (Known to Work board) ? If you get a replacement and it does not work there is a very probability that the tool is not the issue... So next thing to check is the application board and the PC installation (try install MPLAB X on another PC). Regards |
该板是测试板AC164113,所以它是原来的。编程板工作了几个月,没有有效的组件。无论如何,我很有信心这个问题不是在ICD3中,而是在别的地方:我试图找出问题所在,因为我改变了编程环境(编程板和测试板),康妮。Cts(USB电缆)、计算机(桌面和膝上型电脑)和软件(两个不同计算机上的三个MPLABX版本)。RegardsPaul
以上来自于百度翻译 以下为原文 The board is the test board AC164113, so it's original. The programming board worked flawlessly for months and has no active components on. Anyway, I'm fairly confident that the problem is NOT in the ICD3, but somewhere else: I'm trying to pinpoint the problem, since I changed both the programming environment (programming board and test board), the connections (USB cables), the computer (desktop and laptop) and the software (three MPLABX versions on two different computers). Regards Paul |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
503 浏览 0 评论
5812 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3544 浏览 3 评论
1159浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1121浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
888浏览 1评论
503浏览 0评论
/9
GMT+8, 2025-12-13 22:08 , Processed in 0.806998 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2865
