电子发烧友论坛|
大家好,我在MPLAB X 3.15(Wi7 64位)上使用了我的ICD3遇到了一些麻烦。我开发了一个基于DSPIC30F6010A的项目,所有的工作都很好,因为我开始在一个基于DSPIC33 EP256MU810的新项目上工作,我的ICD3不再能够识别和编程设备……通过改变ICD3,新工具运行良好。我已经尝试基于DSPIC30F6010编程旧板,问题仍然存在。回到基于DSPIC306010A的项目中,根据DSPIC306010A返回项目,异想天开的ICD3工作得很好。看来我的工具被“阻塞”了。一个DSPIC30F6010A。我已经验证了正确的固件是在工具上下载的,但是不同于DSPIC30的设备…无法识别。我如何恢复我的ICD3到工厂设置?谢谢你的帮助!伊蒂
以上来自于百度翻译 以下为原文 Hi all, I'm experiencing some troubles using my ICD3 on MPLAB X 3.15 (Win7 64 bit). I've developed a project based on dsPIC30F6010A, and all work fine; since I begin to work on a new project based on a dsPIC33EP256MU810, my ICD3 is no more able to recognise and to program the device... by changing the ICD3, the new tool works fine. I've tryied to program an old board based on a dsPIC30F6010, and the problem persists. Coming back to the project based on the dsPIC306010A, Returning to the project according to dsPIC306010A, the whimsical ICD3 works well. It seems that my tool is "blocked" to work on a dsPIC30F6010A. I've already verified that the proper firmware is downloaded on the tool, but devices different from dsPIC30... are not recognised. How can I restore my ICD3 to the factory settings? Thank you for your help! iTTy |
10个回答
也许重新上传原始固件?(类似的事情也发生在我身上)
以上来自于百度翻译 以下为原文 Maybe re-upload original firmware? (something similar was happening to me too) |
我已经尝试通过指向路径:C:程序文件(x86)/Microchip /MPLABX/V3.15/MPLABBIDE/MPLABLIbs/MuleS/Ext/ICD3.JAR/ICD3FWY01400 5.JAMEL方式下载固件?伊蒂
以上来自于百度翻译 以下为原文 I've already tried to force the firmware download by pointing to the path: C:Program Files (x86)/Microchip/MPLABX/v3.15/mplab_ide/mplablibs/modules/ext/ICD3.jar/ICD3FW_014005.jam Other way to download the firmware? iTTy |
试试V3.61,看看问题是否已经解决了。
以上来自于百度翻译 以下为原文 Try it with V3.61 and see if the problem has been fixed. |
谢谢你的回复!这个晚上我会尝试改变MPLAB X版本…但是要确保下载一个正确的ICD3固件,我在哪里可以找到正确的文件?另一个问题:什么会引起这个问题?
以上来自于百度翻译 以下为原文 Thank you for your replies! This night i will try to change MPLAB X version... But to be sure to download a right ICD3 firmware, where can i find the proper file? Another question: what can cause this issue? |
我几乎可以肯定,所有的FW文件都有一个“日期时间戳”的名字,但是从上面所引用的情况来看,这似乎不是……好吧,我不确定。我是说,我会用最新的一个。
以上来自于百度翻译 以下为原文 I was almost sure that all the fw files have a "date timestamp" in their names, but this does not seem to be the case from what you quote above... Well, not sure then: I mean, I'd use the latest one |
当你在MPLAB X中选择一个新设备时,如果该设备需要新的FW,它将自动下载。3.15是相当旧的,我也建议你下载并尝试3.61。
以上来自于百度翻译 以下为原文 When you select a new device in MPLAB X if new FW is needed for that device it will download automatically. 3.15 is pretty old, I would also suggest you download and try 3.61 |
大家好!我尝试下载和安装MPLAB X 3.61…但问题依然存在!我的ICD3只能用DSPIC30F6010A工作。有一种方法可以执行某种深度重置吗?
以上来自于百度翻译 以下为原文 Hi all! i tried to download and install MPLAB X 3.61... but the problem persists! My ICD3 works only with dsPIC30F6010A. There is a way to perform a sort of deep-reset? |
嗨,你试过用PIC10/12/16/18或32开始一个新项目吗?在启动编程后,MPLAB必须为其他类型的PIC更新ICD3固件。之后,如果没有该PIC连接,编程失败,但是固件应该为该PIC更新。当您继续使用您的项目时,ICD是当您STA时DSIC33 EP256MU810的更新版本。RT编程它,因为现在在ICD上有错误的固件。
以上来自于百度翻译 以下为原文 Hi, have you tried to start a new project with a pic10/12/16/18 or 32? After starting programming, mplab must update the ICD3 firmware for that other kind of PIC. After that, without that pic connected, programming fails, but the firmware should be updatet for that pic. When you continue working with your project, the ICD is updatet for the dsPIC33EP256MU810 when you start programming it, because now there is the wrong firmware on the ICD. |
尝试过,但问题仍然存在!在接下来的日子里,我会打开一个支持小杯……
以上来自于百度翻译 以下为原文 tried, but the problem still persists! in the next days i will open a support tiket.... iTTy |
如果你解释“不工作”是什么意思?否则它太普通了。你有任何输出吗?
以上来自于百度翻译 以下为原文 It would be helpful if you explained what do you mean by "doesn't work"? Otherwise it's too generic. Do you get any sort of output? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:31 , Processed in 2.077907 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2860
