电子发烧友论坛|
是否可以在PLTS 2012中使用8753ES?
连接我的N5242A没问题。 当我连接8753ES(通过GPIB)并使用PLTS扫描新仪器时,PLTS说它找不到任何东西。 同时我注意到8753ES在屏幕上有一条消息。 请原谅我的解释。 我在实验室里把它写下来,忘记了我写的帖子。 这就像是“无话可说”。 我必须跑过实验室并抓住那个音符,因为我知道这不完全是。 我尝试了几个不同的设置,结果相同。 当我将它与N5242A同时连接时,我确保更改了GPIB地址。 然后,我将它更改回16(或者可能是15?)并在测试时将N5242A从总线上断开。 我每次都得到相同的结果。 我不介意通过常规的8753ES菜单进行校准,但能够通过PLTS拉入S参数会很好。 不幸的是,我为8753s所写的所有仪器都回到了研究生院,用labview写的,我再也没有这个了。 哦,好吧,可能正在编写一些新的脚本。 谢谢,迈克尔 以上来自于谷歌翻译 以下为原文 Is it possible to use an 8753ES with PLTS 2012? I have no problems connecting to my N5242A. When I hook up the 8753ES (by GPIB) and scan for new instruments with PLTS, PLTS says it can't find anything. At the same time I notice that the 8753ES has a message on the screen. Forgive me for my paraphrasing. I wrote it down in my lab and forgot the post-it I wrote it on. It was something like "contacted with nothing to say." I have to run past the lab and grab that note, because I know that's not exactly it. I tried a few different setups with the same result. I made sure I changed the GPIB address when I had it connected at the same time as the N5242A. Then, I changed it back to 16 (or maybe 15?) and disconnected the N5242A from the bus while I tested it. I got the same result each time. I don't mind calibrating through the regular 8753ES menus, but it would be nice to be able to pull in the S-parameters through PLTS. Unfortunately, all the instrumentation I wrote for the 8753s was back in grad school, written in labview, and I don't have a seat of that anymore. Oh well, might be writing some new scripts. Thanks, Michael |
1个回答
感谢OJ和Joel博士的回复。
我的偏好可能是通过GPIB将数据拉出来并用自己的脚本将其写入touchstone文件,软盘供不应求,软盘驱动器更难找到。 让我想知道我的一个旧塔中的旧5 1/4“驱动器是否仍然有效,因为我的大多数旧的3 1/2”软盘驱动器很久以前就装好了。 您是否使用旧的Basic代码(或其他语言)使用GPIB / VISA命令从SNA中提取S参数数据? 我曾经有一个8753D年前用过的,但我当时使用的是Labview。 现在,我甚至没有一个查看器来提取我的命令。 谢谢,迈克尔 以上来自于谷歌翻译 以下为原文 Thanks for the responses, OJ and Dr. Joel. My preference would probably be to pull the data over GPIB and write it to a touchstone file with my own scripts, floppy disks being in short supply and floppy drives being even harder to find. Makes me wonder if the old 5 1/4" drive in one of my old towers still works, because most of my older 3 1/2" floppy drives packed it in long ago. Do either you have an old Basic code (or other language) using GPIB/VISA commands to pull the S-parameter data off the VNA? I used to have one that I used for an 8753D years ago, but I used Labview at the time. Now, I don't even have a viewer to extract my commands from. Thanks, Michael |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:41 , Processed in 0.641445 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4686
