电子发烧友论坛|
亲爱的论坛!不幸的是,我为硬件选择了“错误”的PIC24。我希望能够使用MCC支持,但是现在我意识到PIC24HJ64GP502不在列表中。相反,我用MPAB X IDE(3.45)创建了程序,它带有一个简单的设备PIC24FJ64GA102(具有相同的引脚)。(切换IO)。以下是我的问题:我是否应该依赖具有不匹配的P和strat编程的软件设置?调试工作吗?有没有机会为已经焊接的P PIC24HJ64 GP502获得一个图书馆?是否最好取消P的旧版本,并用MCC库(PIC24FJ64GA102)中支持的版本替换它?附加信息应用程序控制两个H桥一个在600Vdc,第二个在1000VDC中压(低电流<30A)开关频率为两个H桥20..30kHz,进一步它管理预加载,一些节省问题和开关一些继电器,总的来说不是很复杂。ted,但是我没有足够的经验来判断“F”设备是否会很快,正如您可能意识到的,我有点不愿深入研究P的所有位和字节,所以我希望MCC在我身边更容易……谢谢您提前的建议!马丁
以上来自于百度翻译 以下为原文 Dear forum! Unfortunately I picked the "wrong" PIC24 for my hardware. I was hoping to be able to use the MCC support, but now I realize that PIC24HJ64GP502 is not in the list. Instead I created my program in MPAB X IDE (3.45) with a simlar device PIC24FJ64GA102 (which has the same pinning). Now I am wondering if this is a good idea allthough it worked for the first try (switching an IO). Here are my questions:
Thank you for your advice in advance! Martin |
3个回答
我宁愿选择其中一个DSPIC3E*类型,因为这些是最新和最快的衍生工具。你可以期待MCC的支持。
以上来自于百度翻译 以下为原文 I'd rather go for one of the dsPIC33E* types. As these are the latest and fastest derivatives. And the ones you could expect to be supported by MCC sooner or later. |
你可以从一个不同的芯片开始,并将它传送到你的芯片上。这就是它在MCC之前的日子里所做的事情。但这取决于你看PIC的数据表,并纠正任何差异。
以上来自于百度翻译 以下为原文 You can start with a different chip and port it to yours. That is how it was done in the old days before MCC. But it is up to you to look at the data sheet for the pic and correct any differences. |
谢谢你们的回复!我会尝试在MCC中附带一个“假”P,并保存已经焊接的一个。如果更糟的话,我仍然可以改变硬件。或者在MCC生成的文件中找出差异,格林先生:所以,再次感谢!马丁
以上来自于百度翻译 以下为原文 Thank you both for your reply! I'll try to come along with a "fake" µP in MCC and keep the one that is already soldered. If worse comes to worst I still can change the hardware... or work out the differeces in the MCC generated files mr green: So again, thank's a lot! Martin |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
503 浏览 0 评论
5812 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3544 浏览 3 评论
1161浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
508浏览 0评论
/9
GMT+8, 2025-12-14 13:12 , Processed in 0.748027 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1132
