电子发烧友论坛|
大家好,我是NeXER嵌入式程序员,我想在MPLAB上使用代码配置器插件,但是我得到一个错误信息,说MCC不支持DeVICEI,我想知道MCC只是针对某些微控制器吗?我使用PIC24HJ32 GP202
以上来自于百度翻译 以下为原文 Hello I am beginer embedded programmer I am trying to use the Code Configurator plug in on mplab but i get an error messgae saying MCC doesnt support device I am wondering does is MCC only for certain microcontrollers? I am using PIC24HJ32GP202 |
14个回答
事实上,对设备的支持是非一般性的:(尝试找到一个与您的PIC尽可能接近的衍生物-从PIC24HJXXXGP202开始)。(xxx:任何内存大小代码)
以上来自于百度翻译 以下为原文 As it is, support for devices is non-generic :( Try to find a derivative that is as close to your PIC as possible - starting with PIC24HJxxxGP202. (xxx: any memory size code) |
是的,我今天安装的最新版本是MPLABX IDE V3.55
以上来自于百度翻译 以下为原文 Yes I have the lastest version installed the plug in today is MPLABX IDE v3.55 |
“最新版本”是一个橡皮图样。MPLABX版本3.60现在不在了。
以上来自于百度翻译 以下为原文 "Latest version" is a rubbery figure. MPLABX version 3.60 is out now. |
嗨,MCC没有覆盖非常老的PIC.PIC24HJ32 GP202大概是10岁,所以它可能没有计划顶部支持它。
以上来自于百度翻译 以下为原文 Hi, MCC does not cover the very old PICs. PIC24HJ32GP202 is probably about 10 years old so it may not be planned top support it. Regards |
哦,对不起,我没有意识到我在错误的论坛里,我还不知道这个论坛是如何运作的。
以上来自于百度翻译 以下为原文 oops sorry didnt realise i was in the wrong forum im new and still learning about how this forum works |
HI,目前在MCC不支持PIC24HJ32 GP202设备。支持的设备列表可以在发行说明中找到。http://www. MICROCHEM.COM/MPLAB/MPLAB代码配置器,MCC团队。
以上来自于百度翻译 以下为原文 Hi, Currently PIC24HJ32GP202 device is not supported in MCC. List of devices that are supported can be found in the release notes. http://www.microchip.com/mplab/mplab-code-configurator Regards, MCC team |
无意冒犯。当我进入你的链接时,文档会得到它的发行说明。
以上来自于百度翻译 以下为原文 No offense intended. When I go to your link, Documentation to get the release notes it says 11 Appendix: Supported Devices For the list of supported devices, refer to the release notes of respective library. |
我下载当前的库“PIC24DSPIC33-PIC32 MyV1.21.1.zip”文件,在我找到的“PIC24DSPIC33-PIC32 MMYV1.21.1.jar”文件中,当我双击文件时,我什么也看不到。如果我尝试用“Java”从CMD提示符中执行.jar,如果我重命名.jar到zip,我可以打开zip并浏览DIR为设备文件的列表。或者我可以打开NETBeCide IDE中的.jar来查看JARIF中的设备。我从MPLAB X中尝试使用这个设备。它报告不支持这个设备,并说在库中查找。这似乎是一个catch 22.肯定有一个更好的/更简单的方法。D支持的设备?
以上来自于百度翻译 以下为原文 I download the current library "pic24-dspic33-pic32mm_v1.26.1.zip" file Within I find "pic24-dspic33-pic32mm_v1.26.1.jar" file When I double click on the file I see nothing happen. If I try to execute the .jar from a cmd prompt with "java" D:DownloadsMicrochipMplabXMCCpic24-dspic33-pic32mm_v1.26.1>java pic24-dspic33-pic32mm_v1.26.1.jar Error: Could not find or load main class pic24-dspic33-pic32mm_v1.26.1.jar If I rename the .jar to .zip I can open the zip and browse the D:DownloadsMicrochipMplabXMCCpic24-dspic33-pic32mm_v1.26.1pic24-dspic33-pic32mm_v1.26.1 - Copy.jarcommicrochipmccmcu16resourcesdevices dir for a list of the device files. Or I can open the .jar in netbeans IDE to see the devices within the .jar If I try from within Mplab X with this device it reports this device is not supported and says look in the library. This seems to be a catch 22 Surely there must be a better/simpler way to find the supported devices ? |
与MCC PIC24DSPICPIC32 mm库相关的发行说明给出了受支持设备的列表:HTTP:/WW1.MICCHIP.COM/DeLoSs/En/DeVICEDC/OFRESASEYNOTESSPIC24YDSPICEPIC32 MMYV126261.1.PDF
以上来自于百度翻译 以下为原文 The release notes related to MCC PIC24dsPICPIC32MM library gives the list of supported devices: http://ww1.microchip.com/downloads/en/DeviceDoc/release_notes_pic24_dspic_pic32mm_v1_26_1.pdf |
当然,你是对的。我想知道我是如何从这个页面得到那个文件的?http://www. McCAM.COM/…PLAB代码配置器
以上来自于百度翻译 以下为原文 ns.mchp, Yes of course you are quite correct. I wonder how I get to that file from this page ? http://www.microchip.com/...plab-code-configurator |
Hi,在网页的某个地方,有一个标签:“当前下载”,有14个不同的安装包,MCC和ASCOCOCIATE程序包的不同部分,每个都有它自己的版本号,一个发行说明文档和一个ZIPFILE。有一个很好的选择PIC24FJ…支持的设备,没有DSSPIC33 FJ…没有……所有的设备,然后有一些DSPIC33 EP…和DSPIC33 EV,总共有258个不同的设备从16位PIC家族。迈西尔
以上来自于百度翻译 以下为原文 Hi, Somewhere down in the webpage, there is a tab: 'Current Download' with 14 different installation packages with different parts of MCC and asscociated library packages, each with it's own version number, a release notes document, and a zipfile. There is a good selection of PIC24FJ... devices supported, No dsPIC33FJ... and no ...HJ... devices at all. Then there is a number of dsPIC33EP... and dsPIC33EV..., in total 258 different devices from 16 bit PIC families. Mysil |
Mysil,非常好。对我来说太微妙了,我错过了发行说明栏目,我一直点击图书馆名称……向NS.MCHP道歉。
以上来自于百度翻译 以下为原文 Mysil, Very good. Too subtle for me, I missed the Release Notes Column, I kept clicking on the Library Name.. Apologies to ns.mchp |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
503 浏览 0 评论
5812 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3544 浏览 3 评论
1161浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
508浏览 0评论
/9
GMT+8, 2025-12-14 11:48 , Processed in 1.194236 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1527
