电子发烧友论坛|
6个回答
你好:
我的CPU使用I2C IAP块标准程序STM8A并自动更新MCU,总块时间为15块标准程序,即10秒。是时候慢还是正常? 问候 wolver 以上来自于谷歌翻译 以下为原文 Hello: My CPU use I2C IAP block standard programm STM8A and automatic updates MCU, Total time of 15 blocks standard programm which is 10 seconds. Is that time slow or normal? Regards wolver |
嗨沃尔弗,
块(128字节)的编程时间约为6毫秒(包括擦除+编程时间)。如果你做一个字节或单词profgramming也一样。对于15个块=> 15 * 6 = ~90毫秒。 我想,10秒是通过I2C接收数据然后将其加载到存储器位置所需的总时间。你的cpu频率是多少? 您可以通过切换一些IO来计算代码的每个部分所花费的时间。 [此消息由Jatin于14-05-2009 09:12编辑] 以上来自于谷歌翻译 以下为原文 Hi Wolver, The programming time for a block(128 bytes) is ~6msec (which includes erase+program time). Its same if you do a byte or word profgramming. For 15 blocks => 15*6 = ~90 msec. I think, 10 seconds is the total time taken to receive the data through I2C then loading it in the memory locations. what is your cpu frequency? You can calculate the time taken by the each section of your code by toggling some IOs. [ This message was edited by: Jatin on 14-05-2009 09:12 ] |
嗨贾丁
我的CPU工作(Linux_OS)在333MHz,I2C总线是100KHz,STM8A是从机。 我测试它并确保更新成功。 一切都是块标准程序,它不是字节或字程序... : - [ 问候 wolver 以上来自于谷歌翻译 以下为原文 Hi Jatin My CPU work(Linux_OS) on 333MHz, I2C bus is 100KHz, STM8A is slave. I test it and sure that update is successful. All is block standard programm, It do not a byte or word programm... :-[ Regards wolver |
嗨贾丁
你是对的!我查看我的程序,发现我忘了...如下: //启用阻止程序 FLASH_CR2 = BIT(0); FLASH_NCR2& =(u8)~BIT(0); 现在,15块程序不到1秒。我认为这是正常的。 :-D Redards wolver 以上来自于谷歌翻译 以下为原文 Hi Jatin You are right! I check my programm, find I forget ... as follow: // Enable Block programm FLASH_CR2 = BIT(0); FLASH_NCR2 &= (u8)~BIT(0); Now, 15 blocks programm is less than 1 second. I think that it is normal. :-D Redards wolver |
嗨沃尔弗,
15个块的实际块编程时间是=> 15 * 6 = 90毫秒。 加载块中的最后一个字节时,编程开始。所以我想1秒。时间还包括数据加载阶段加上通过I2C接收数据的时间。 以上来自于谷歌翻译 以下为原文 Hi Wolver, The actual block programming time for 15 blocks is => 15 * 6 = 90 msec. The programming starts when you load the last byte in the block. So i suppose the 1 sec. time also includes the data loading phase plus the time to receive the data via I2C. |
嗨贾丁
我测试了STM8AF-51A8的结果: 所有1024个块(addr = 0x008000~0x027fff)标准程序的总时间约为30秒。平均约30mS @ block> 6ms的 当然,那个时间(30mS @ block)包括:预处理+通信(IAP I2C)+擦除+编程+验证 我很高兴我可以发布我的汽车产品,从不担心MCU的错误...因为我的CPU可以更新MCU程序... :-D 问候 wolver [此消息由:wolver于16-05-2009 07:41编辑] 以上来自于谷歌翻译 以下为原文 Hi Jatin I test STM8AF-51A8 result: All total time of 1024 blocks(addr = 0x008000~0x027fff) standard programm is about 30 seconds. Average about 30mS @ block > 6mS of course, That time(30mS @ block) includes: Pretreatment + communication(IAP I2C) + Erase + Programm + Verify I am glad that I can release my automotive products and never to worry MCU bug...since my CPU can update MCU programm... :-D Regards wolver [ This message was edited by: wolver on 16-05-2009 07:41 ] |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 01:24 , Processed in 0.777654 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
924
