电子发烧友论坛|
我们有一个产品,我们已经发展了一段时间,我们都面临着一个问题,睡眠时间延长超过1s设置在较低的温度下和在某些情况下不显示出来的睡眠。我们使用的是EXT 32 KHz振荡器。我试图找出问题的根源。切换到内部振荡器似乎解决这个问题,但这是不准确的。什么会影响与psoc1 extermnal振荡问题。是啊,我们几乎每一块(数字和模拟)断电以节省电力。
以上来自于百度翻译 以下为原文 We have a product that we have had developed for some time and we are experiencing a problem where the sleep time is lengthening beyond the 1s setting at low temperature and in some cases does not appear to come out of sleep. We are using an ext 32Khz oscillator. I am trying to identify the source of the problem. Switching to the internal oscillator seems to fix the issue but this is inaccurate. What would affect extermnal oscillator issues with the PSOC1. Oh yeah, we have practically every block (both digital and analog) powered down to conserve power. |
3个回答
这些可能有帮助。
CyPress?DOCID=32328 CyPress?DOCID=33272 前者包括Ioo创业问题。 问候,Dana。 以上来自于百度翻译 以下为原文 These may help - www.cypress.com/?docID=32328 www.cypress.com/?docID=33272 Former includes IMO Startup issues. Regards, Dana. |
你提到的问题似乎是-R问题。我建议您尝试将ECOTYTR寄存器设置更改为中高或最高振幅模式(参照寄存器设置AN2027)。这将增加设备的R,并确保设备正确启动。
最好的问候, 普什克 以上来自于百度翻译 以下为原文 The problem you have mentioned seems to be the -R problem. I suggest you to try changing the ECO_TR register setting to Medium HIGH or the HIGHEST amplitude mode (refer to AN2027 for register setting). This will increase -R of the device and will ensure that device does start properly. Best regards, Pushek |
XTAL振荡器是“棘手”的故障排除,XTAR参数的阻抗测量困难,因为Z的范围,探头看振荡器运行必须是超低C,因为你正在处理非常低的振荡器C值开始。为了克服这个问题,使用具有高灵敏度的范围,并且通过HI系列R或低C值从OSC节点解耦探针以最小地影响OSC。
XTAL振荡器通常工作在非常高的共振产生的值,容易受到任何“触摸”它们的影响。 谷歌“晶体振荡器基本应用说明”,大量的AP笔记。 特别注意的事实是,外部XTAL C比在XTAL和2个盖帽的有效传递函数中提供电压增益。 问候,Dana。 以上来自于百度翻译 以下为原文 Xtal oscillators are “tricky” to troubleshoot, impedance measurements of Xtal parameters difficult because of range of Z’s, probes to look at oscillator running have to be ultra low C as you are dealing with very low oscillator C values to start with. To overcome this problem use scopes with high sensitivity, and decouple probe from Osc nodes via Hi series R or low C values to minimally affect Osc. Xtal oscillators typically operate at very hi Z resonant produced values, easily affected by anything that “touches” them. Google “crystal oscillator basic application note”, lots of ap notes. Pay particular attention to the fact that external Xtal C ratios provide voltage gain in the effective transfer function of the Xtal and the 2 caps. Regards, Dana. |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7367 浏览 0 评论
2486 浏览 1 评论
2178 浏览 1 评论
4045 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2089 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7866浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6430浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
759浏览 2评论
730浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8278浏览 2评论
/9
GMT+8, 2025-12-14 11:20 , Processed in 1.360596 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3029
