电子发烧友论坛扫一扫,分享给好友
对于Real-Dead的原因,我需要至少在PC的USB端口上放置四个CY7C68013A(EZ-UB-FX2)设备,但是我不知道我的应用软件如何知道哪一个是正确的控制软件?或者,如果我打开了应用程序WAFWATES的四个实例,四个实例和四个设备如何可以一一对应?谢谢您!
以上来自于百度翻译 以下为原文 For coast down reason, i need put at least four CY7C68013A(EZ-USB-FX2) devices on one PC's USB ports, but i don't know how my application software to know which one is the correct one to control? or, if i open four instances of the application waftware, how can the four instances and the four devices can be one to one correspondence? thank you! |
3个回答
你好,
您使用CyPress库来进行主机应用程序开发吗?您可以根据VID/PID值选择设备。 请看HTTP://wwwyCyp.com/?RID=12974,HTTP://www. CyPress?COM/?RID=53165和HTTP://www. CyPress?COM/?RID=43538,这些ANS会对你有所帮助。 你能告诉我们更多关于你的申请,以便我们能帮助你吗? 谢谢 普拉吉斯 以上来自于百度翻译 以下为原文 Hi, Are you using cypress library for Host application development? You can select devices based on VID/PID value. Please see http://www.cypress.com/?rID=12974, http://www.cypress.com/?rID=53165 and http://www.cypress.com/?rID=43538, these ANs would be helpful for you. Can you tell us more about your application so that we can help you out. Thanks Prajith |
您好,我很抱歉手提打滑点击“报告滥用”。是的,我使用CysUBLIB在VC++ 6平台上创建了一个应用程序。LIB有一个功能BooCysUbDea::打开(UCHAR DEV)来打开不同的CY7C68013A设备,但是我不知道如何将数据发送到我想要的一个设备。如果XFelDATA()能知道它呼啸的设备发送给什么?还是别人能做的功能?谢谢!
我的设计结构是: 当我打开它时,使用应用程序将固件下载到CY7C68013A的RAM中。 使用XFelDATA()将数据传输到CY7C68013A 当固件得到数据时,使用“开关”来决定根据数据调用哪一个函数。 以上来自于百度翻译 以下为原文 Hi, i'm sorry for hand slip to click the "report abuse". YES, I used CYUSB.LIB to create a application in vc++ 6.0 platform, this .lib has a function bool CCyUSBDevice::Open(UCHAR dev) to open different CY7C68013A devices, but i don't know how to sent data to the one device that i want. If the XferData() can know whiche device it shout send to? or someone else function can do it? thanks! the structure of my design is: useing application to download firmwire into CY7C68013A's RAM everytime when i open it. useing Xferdata() to transfer data to CY7C68013A when firmwire get the data, useing "switch" to decide which function should be called base on the data. |
你好,
使用下面的代码识别您的设备号,然后使用数据。 /查找具有VID=0547,PID=1002的设备。 CysUbStudio*UsButoDe=新CysUbDebug(NULL);/ /创建cCysBB设备的实例 INTeals= UBStuts&Gt;DeVeCeCuffTo(); It VID,PID; int=0; 做{ 打开(d);//如果需要,打开/自动调用Clute() VID=USB设备-GT;VendorID; PID = UB-设备-GT;ProductID; D+; }((d & lt;设备)&&;(VID)!= 0x054)和(PID)!= 0x1002); 谢谢 普拉吉斯 以上来自于百度翻译 以下为原文 Hi, Using below code identify your device number and then thransfer data. // Look for a device having VID = 0547, PID = 1002 CCyUSBDevice *USBDevice = new CCyUSBDevice(NULL); // Create an instance of CCyUSBDevice int devices = USBDevice->DeviceCount(); int vID, pID; int d = 0; do { USBDevice->Open(d); // Open automatically calls Close() if necessary vID = USBDevice->VendorID; pID = USBDevice->ProductID; d++; } while ((d < devices ) && (vID != 0x0547) && (pID != 0x1002)); Thanks Prajith |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 02:55 , Processed in 0.744213 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1452
