电子发烧友论坛|
你好,
我有一块EVALSTPM34板。 我正在尝试使用'STPM3x评估软件'v3.1.0.0通过UART访问电路板 J7附带3.3v电源。 J2附有TTL-232R-3V3电缆。 PC将TTL-232R-3V3识别为COM5。 J3跳线被移除。 SW1使所有SW处于ON位置。 我启动了STPM3x评估软件。 选项&gt;接口= USRT,COM5,9600 我按'打开'即可获得成功。 选项&gt;配置&gt;应用程序选项卡= EVAL-STPM34 我按下“应用”并弹出一个对话框,显示: &LT;是的,“长度”拼写错误。 有没有人有类似的经历? 是否有更新版本的'STPM3x评估软件'? Rob Parsons 施耐德电气 Knightdale NC USA 以上来自于谷歌翻译 以下为原文 Hello, I have an EVALSTPM34 board. I am trying to access the board via the UART using the 'STPM3x Evaluation Software' v3.1.0.0 J7 has 3.3v supply attached. J2 has TTL-232R-3V3 cable attached. PC recognizes the TTL-232R-3V3 as COM5. J3 jumper is removed. SW1 has all SWs in ON position. I start up the STPM3x Evaluation Software. Options > Interface = USRT, COM5, 9600 I press 'Open' and get success. Options > Configuration > Application tab = EVAL-STPM34 I press 'Apply' and get a pop-up dialog box that says: < Yes, 'length' is mis-spelled. Has anyone had a similar experience? Is there a newer version of the 'STPM3x Evaluation Software' ? Rob Parsons Schneider Electric Knightdale NC USA |
3个回答
Parsons.Rob
“我尝试将EVAL-STPM32板连接到STPM3x评估软件,但在尝试读取数据时遇到以下错误。 错误消息:'读取缓冲区长度不足。操作已超时。' PC运行的是Windows 7 STPM3x评估软件v3.1.0.0 在'选项 - &gt;接口'菜单,使用以下值:UART / COM 5/9600(波特率) 该板通过USB到UART桥接器(Silicon Labs CP210x)连接到PC。 J2连接到USB-to-UART桥接器 J7连接到3.3VJ2的外部直流电源,连接到不同的3.3V电源 J3跳线被移除 SWC1 DIP开关全部处于开启位置 J4跳线位于“启用”位置我真的很感谢你的帮助。 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Parsons.Rob ‌I tried to connect the EVAL-STPM32 board to the STPM3x Evaluation Software but encountered the following error when trying to read data. Error message: 'Read buffer length insufficient. The operation has timed out.' PC was running Windows 7 STPM3x Evaluation Software v3.1.0.0 In the 'Options -> Interface' menu, the following values were used: UART / COM 5 / 9600 (baud rate) The board was connected to the PC through a USB to UART Bridge (Silicon Labs CP210x). J2 connected to the USB-to-UART bridge J7 connected to an external DC supply of 3.3VJ2 connected to a different 3.3V source J3 jumper was removed SWC1 DIP switch was all in on position J4 jumper was in 'enable' positionI really appreciate your help. Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
你好!解决这个问题有没有成功?我也有同样的问题!请帮忙!谢谢
以上来自于谷歌翻译 以下为原文 Hello! Was there any success in solving this issue? I have the same problem! Please help! Thank you |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1469 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
747浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
727浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
968浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
770浏览 5评论
/9
GMT+8, 2025-12-11 20:09 , Processed in 0.691633 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1898
