电子发烧友论坛|
我的一个朋友给了我这个板上的加速度计,但我没有与加速度计有关的套件。我使用PSoC创建者2,有人想给我一个项目与加速度计?
谢谢您 以上来自于百度翻译 以下为原文 A friend of mine gave me this board to try the accelerometer on it but i don't have the kit related to the accelerometer. I am using PSoC creator 2.0, someone would like to give me a project exemple with the accelerometer? thank you |
14个回答
我假设你在这里提到这个工具包,HTTP://www. CyPress。RID=38235。如果是,那么你可以下载这个工具包的安装程序,它将安装用户指南。遵循用户指南,您应该能够找到示例代码,演示了在这个工具包上使用加速度计。
如果你想连接任何其他标准加速度计,让我们知道。 以上来自于百度翻译 以下为原文 I am assuming that you are referring to this kit here, http://www.cypress.com/?rID=38235 . If yes, then you can download the installer for this kit, which will install the User Guide. Follow the user guide and you should be able to find the example code that demonstrates the use of accelerometer on this kit. If you intend to interface any other standard accelerometer, let us know. |
4.1.1启动工具包指南
这正是我所缺少的,代码示例。当我打开PSoC创建者,工具包内容是空白的。它们是从自定义安装中获得的,因为我已经安装了具有典型设置的软件。 以上来自于百度翻译 以下为原文 4.1.1 of the starter kit guide This is exactly what i am missing, the code examples. When i open up psoc creator, the kit content is blank. Are they available from a custom installation because i`ve installed the software with typical settings. |
这是下载CD的内容吗?CY8CKIT-03PSoC 3 FTK套件(KIT设计文件、文档、实例)?
以上来自于百度翻译 以下为原文 Is this download the content of the CD ? CY8CKIT-003 PSoC 3 FTK Kit Only (Kit Design Files, Documentation, Examples) ? |
你好琶音,
请下载和安装从“CY8CITK-03PSoC 3 FTK工具包只”文件,你在前面的评论中提到。 将安装与FTK(第一触控套件)相关的5个示例项目。然后,您可以将项目计划到您的FTK。 以上来自于百度翻译 以下为原文 Hi arpeggio, Please download and install from the "CY8CKIT-003 PSoC 3 FTK Kit Only" file which you have mentioned in the previous comment. The 5 example projects associated with the FTK (First Touch Kit) will be installed. You can then program the project onto your FTK. |
我已经下载的程序和加载的泡沫水平成功的例子!现在你如何告诉X,当我倾斜板在我的左边右边的LED点亮,当我倾斜到我的右边,左边的LED点亮,所以X轴是平行的发光二极管?
以上来自于百度翻译 以下为原文 I've downloaded the program and loaded the bubble level example successfully! Now how do you tell the X-axis, when i tilt the board on my the left the rightmost led turns on, when i tilt it to my right, the leftmost led lits on , so the x-axis is paralle to the leds? |
Arpeggio
FTK有一个三轴加速度计KXSC7—2050。该加速度计的规格可以在其数据表中找到。 在“气泡水平”项目中,加速度计的X轴被利用。它连续读取X轴,并使用Delsig ADC将其转换成数字值。读取的值是板沿X轴倾斜的指示。 倾斜值偏移和缩放以更新LED显示器。 您可以参考示例项目并阅读评论来理解它的工作。 以上来自于百度翻译 以下为原文 Arpeggio, The FTK has a triple axis accelerometer KXSC7-2050. The specs of this accelerometer can be found in its datasheet. In the "Bubble Level" project, the X-axis of the accelerometer is utilized. It continuously reads the X-axis and converts it to a digital value using Delsig ADC. The value read is an indication of the tilt of the board along X axis. The tilt value is offset and scaled to update the LED display. You can refer to the example project and read the comments to understand its working. |
更新您的PSoC创建者或安装最新版本的PSoC创建者从CyPress WebSIT。连接您的套件到计算机,并启动PSoC创建者,在右边去示例项目那里你找到程序与示意图和代码加速计。
以上来自于百度翻译 以下为原文 Update your psoc creator or install latest version of psoc creator from cypress websit. Connect your kit to computer and launch psoc creator and in right side go to sample project there you find program with schematic and code on accelerometer . |
如果你想要PSOC示例项目的截图,我也会发送给你。
以上来自于百度翻译 以下为原文 If u want screenshot of psoc example project I'll send u that also. |
第一次触摸启动套件由柏树到链接下面给出
HTTP://www. CyPress?COM/?RID=38235 以上来自于百度翻译 以下为原文 For first touch start kit by cypress go to link given below http://www.cypress.com/?rID=38235 |
第一触启动器工具包用户指南,其中包含关于工具包的所有信息和关于示例项目
转到链接: HTTP://www. CyPress?COM/?DOCID=29790 它将给出示例项目的示意图和代码。 以上来自于百度翻译 以下为原文 First touch starter kit user guide which contain all information about the kit and about sample projects Go to link: http://www.cypress.com/?docID=29790 It will give sample projects schematic and codes. |
所以我启动了气泡程序并运行,效果不错!我还试图改变校准值,但是在我所在的地方,默认值很好。
使用相同代码的另一个小应用程序: 把木板与桌面平行,并在一侧加速,阵列的另一边的灯就会亮起来。希望这有助于理解加速度计。 以上来自于百度翻译 以下为原文 So i got the bubble level program up and running and it works fine! I`ve also tried to change the calibration values but where i live it is fine with the default values. Another little application with the same code: Put the board as much parallel to your desk and give it an acceleration on one side, the LED on the other side of the array should light up. Hope this helps understand the accelerometer. |
琶音,
加速度计既响应静态(加速度由于重力)和动态加速度(由于运动)。如果在不改变其方向的情况下,以加速/减速的方式移动板,则加速度计的输出的变化纯粹是基于由于运动引起的加速度。 以上来自于百度翻译 以下为原文 arpeggio, The accelerometer responds to both static (acceleration due to gravity) and Dynamic acceleration (due to movement). If you move the board with an acceleration / deceleration without changing its orientation, then the change in the output of the accelerometer will be purely based on the acceleration due to movement alone. |
燃烧PSoC岩石程序并检查板加速度计
以上来自于百度翻译 以下为原文 Burn the psoc rock program and check the board accelerometer |
PSoC的加速度计的程序让你在PSoC板使用加速度计的最直观的想法
以上来自于百度翻译 以下为原文 Psoc accelerometer program gives you best intuitive idea of accelerometer use in psoc board |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 03:03 , Processed in 3.741888 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2512
