亲爱的,我的HP 83640A工作正常(频率,电平,扫描)从2.4GHz到40GHz,但从10MHz到2.4GHz的低频带在频率上存在问题。
在该频段上,频率恰好比所显示的频率低100 MHz。例如,当CW显示为1GHz时,产生的实际频率为900MHz。 这种100 MHz负偏移在低频段完全受到尊重。 水平很好。没有在服务手册和故障排除手册中找到任何相关信息。也无法找到这个发电机的CLIP。我会非常感兴趣的是有人可以给我一些帮助。谢谢提前.Greetings,DominiqueB 以上来自于谷歌翻译 以下为原文 Dear all, My HP 83640A is working fine (frequency, level, sweep) from 2.4GHz up to 40 GHz, but the Low Band from 10MHz up to 2.4GHz has an issue on the frequency. On this band, the frequency is exactly 100 MHz below the frequency displayed. For example, with a CW displayed of 1GHz, the actual frequency produced is 900MHz. This 100 MHz negative shift is exactly respected on the Low Band. The level is fine. Not found any relevant information on the Service Manual nor in the Troubleshooting Manual. And impossible to locate the CLIPs for this generator. I would be very interested is somebody could give me some help. Thanks in advance. Greetings, DominiqueB |
5个回答
嗨DominiqueB-当83640A切换到低频段,10 MHz到2.4 GHz时,通过使用100 MHz参考信号对YO进行外差来获得频率。
您的设备可能已经丢失了低频段组件的100 MHz参考信号,或者低频组件本身存在YP与100 MHz参考信号混合的问题。我希望这有助于 - 以上来自于谷歌翻译 以下为原文 Hi DominiqueB - When the 83640A is switched to low band, 10 MHz to 2.4 GHz, the frequency is derived by heterodyning the YO with the 100 MHz reference signal. Your unit has probably lost the 100 MHz reference signal to the low band assembly, or the low band assembly itself has a problem where the YP is mixed with the 100 MHz reference signal. I hope this helped - |
醉狼工作室 发表于 2019-4-23 18:17 嗨Tabbott,感谢您的回答。来自A7参考的100MHz 0dBm是好的,并且很好地到达了集团A24低频段的输入。 所以频率合成很好......但低频段A24似乎有问题。 是否可以打开这个块并检查里面的元素?是否有任何文件与这个Low Band元素相关?感谢您的帮助。欢呼,DominiqueB。 以上来自于谷歌翻译 以下为原文 Hi Tabbott, Thanks for your answer. The 100MHz 0dBm coming from A7 reference is good and arrives well at the input of the bloc A24 Low Band. So the frequency synthesis is fine ... but the Low Band A24 seems to have problem. Is it possible to open this block and check the elements inside ? Is there somewhere any documents related to this Low Band element ? Thanks for your help. Cheers, DominiqueB. |
国电赛邵 发表于 2019-4-23 18:29 亲爱的,有了故障排除指南,我继续研究。 奇怪的是,在没有任何硬件修改的情况下,我现在在运行Selftest Full时收到错误消息:“+失败:RF低频段调谐电压 - 参考修理手册段落RF.000 +”“+ V - 调谐mV:测量: - 201mV最小值: - 11000mV最大值: - 400 mV +“并且:”+失败269.000 RF:低频带锁定检查+“”+ HTE未锁定+“并且,当发生器工作时,如果我在10MHz和2.3GHz之间编程CW,我收到消息”+ 解锁(HET解锁)+“。 我今天在这里,我将继续探索手册,但如果没有原理图,这并不容易。 我非常有兴趣了解* A24低频模块*(5086-7463)内部的信息,以及*获取A20接口板原理图*。 实际上,故障排除手册将这两个元素作为可能的故障元素集中在一起。 我很想知道*什么意思是“HTE”*,以及哪个板(或模块)位于故障PLL。 我没有在手册中找到这个。 任何信息都会非常受欢迎。 非常感谢你的帮助。 DominiqueB。 编辑:DominiqueB于2012年8月10日上午7:33编辑:DominiqueB于2012年8月10日上午7:39 以上来自于谷歌翻译 以下为原文 Dear all, Having got the Troubleshooting Guide, I went ahead on the research. Strangely, without any hardware modification, I get now an error message when running the Selftest Full : " +Failed : RF Lowband Tuning Voltage - Refer Repair manual Paragraph RF.000+" " +V - Tune mV : Meas : - 201mV Min : - 11000mV Max : - 400 mV+" And : " +Failed 269.000 RF : Lowband Locked Check+" " +HTE Unlocked+" And, when the generator is working, if I program a CW between 10MHz and 2.3 GHz, I get the message "+Unlock (HET Unlock)+". Here I am today, I will continue exploring the manuals, but it's not easy without the schematics. I would be very interested to have information on *what is there inside the A24 Low Band module* (5086-7463), and as well *to get the schematic of the A20 Interface board*. Actually, the Troubleshooting Manual focus onto these two elements as a possible faulty elements. I would be interested to know *what means "HTE"*, and in which board (or module) is located the faulty PLL. I didn't found this in the manuals. Any information will be really welcome. Thanks a lot for your help. DominiqueB. Edited by: DominiqueB on Aug 10, 2012 7:33 AM Edited by: DominiqueB on Aug 10, 2012 7:39 AM |
亲爱的DominiqueB我刚从我的83640遇到了同样的错误消息,并在两年前发现了你的帖子。
我想知道你是否终于找到了解决方案。 如果你能给我一个提示,我会很高兴的。 df2fq 以上来自于谷歌翻译 以下为原文 Dear DominiqueB I just encountered the same error message from my 83640 and found your post from two years ago. I am wondering if you finally found a solution. I would be happy if you could give me a hint. df2fq |
嗨df2fq,是的,问题通过交换HET模块解决了。
该模块覆盖10MHz至2GHz的低频。 该模块有自己的调平,因此交换后无需任何调整。 在我的情况下,水平和平坦度立即好。 请注意,此模块在所有版本A,L,B和所有型号中都相同,包括用作VNA源的单位。 我以非常合理的价格在着名的美国海湾找到了更换模块。 交流很容易。 最好是获得一个工作模块而不是维修,例如美国公司提供的模块。 维修成本巨大且可靠性差。 看起来这些模块非常具体,不易修复。 如果您需要更多信息,请与PM联系。 干杯,多米尼克B. 以上来自于谷歌翻译 以下为原文 Hi df2fq, Yes, problem solved with the exchange of the HET module. This module cover the low frequency's from 10MHz to 2GHz. The module has its own leveling, so after exchange, no need of any adjustment. In my case, the level and flatness have been good immediately. Note this module is identical in all the versions A, L, B and for all models, including the units used as source for VNA's. I have found the replacement module on the famous US Bay at very fair price. Exchange is easy. It's better to get a working module instead of repair such as offered by a company in the US. Cost of repair is huge and reliability poor. It seems these modules are very specific and not repairable easily. If you need some more infos, contact me by PM. Cheers, DominiqueB |
只有小组成员才能发言,加入小组>>
2100 浏览 1 评论
1856 浏览 1 评论
1714 浏览 5 评论
2582 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
504浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1412浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
274浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-27 12:00 , Processed in 1.146029 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
