电子发烧友论坛|
亲爱的,我的HP 83752A具有从2.0GHz到2.20GHz的解锁问题。
在这个窗户之外,它很棒。 实际上,它在10MHz到1.999999999GHz和1Hz以上(2.0 ...... GHz)下工作正常,它解锁到2.20GHz。 这个问题在CW或清扫时都会出现。 阅读手册,看起来从10 MHz到2 GHz的HTE频段很好,但是从我的情况开始从2GHz开始的频段0“太晚了”。 没有找到明显的调整来执行阅读服务手册。 如果有人能建议我修复这个精细的发电机,我会很高兴。 谢谢阅读。 最好的,DominiqueB 以上来自于谷歌翻译 以下为原文 Dear all, My HP 83752A has an Unlock issue from 2.0GHz to 2.20GHz. Outside of this windows, it works great. Actually, it works fine from 10MHz to 1.999999999GHz and one Hz above (2.0...GHz), it unlocks till 2.20GHz. This issue comes both on CW or when sweeping. Reading the Manual, it appears the HTE band from 10 MHz to 2GHz is fine, but the Band 0 starting from 2GHz starts in my case "too late". Not found obvious adjustment to perform reading the Service Manual. I would be very happy if somebody could suggest me something to do to repair this fine generator. Thanks for reading. All the best, DominiqueB |
1个回答
您好,感谢您的回答。
也许我对这个问题的描述还不够清楚。 实际上,3频段(HTE频段从10MHz到2GHz,频段0从2到11GHz,频段1从11到20GHz)工作正常。 我只是在HTE频段(工作正常至1.999999999GHz)和频段0之间有一个“漏洞”,它在2.100 GHz开始*而不是2.00000000GHz *。 在这个间隙内(大约100MHz,信号是Unlocked和Unleveled。所以我想有一些事情可以使Band 0从正确的频率开始。感谢你的帮助。问候,DominiqueB 以上来自于谷歌翻译 以下为原文 Hello, Thanks for your answer. Maybe I haven't been clear enough in the description of the issue. Actually, the 3 bands (HTE Band from 10MHz to 2GHz, Band 0 from 2 to 11 GHz and Band 1 from 11 to 20 GHz) are working fine. I just have a "hole" between the HTE band (working fine up to 1.999999999GHz) and the Band 0 which starts *at 2.100 GHz instead of 2.00000000GHz*. Inside this gap (100MHz roughly, signal is Unlocked and Unleveled. So I guess there is something to do to make the Band 0 starting at the right frequency. Thanks for your help. Regards, DominiqueB |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 06:29 , Processed in 0.992542 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5011
