电子发烧友论坛|
大家好,我有一个70k系统,配置如下:70206A系统图形显示70900A:Rev 88090170902A:Rev 87102770908A:Rev 87072170300A:Rev 870910我希望能够使用倍频器使用跟踪发生器扫描频率但是
当我激活跟踪发生器时,频谱单元的测量值不超过2.9 ghz。是否可以通过扫描发生器解除RF部分的控制来执行此测量? 我在菜单中找不到任何选项?非常感谢您的支持。 亲切的问候/最好的73sStephan ON4WX 以上来自于谷歌翻译 以下为原文 Hi All, I have a 70k System with the following configuration: 70206A System Graphic Display 70900A: Rev 880901 70902A: Rev 871027 70908A: Rev 870721 70300A: Rev 870910 I would like to have the capability to sweep the frequency with the tracking generator using a frequency multiplier but when I activate the tracking generator, the spectrum unit doesn't measure above 2.9 ghz. Is it possible to perform this measurement by disengaging the control of RF Section by the sweep generator ? I don't find any option in the menu ? Thanks a lot for your support. Kind Regards / Best 73's Stephan ON4WX |
1个回答
嗨 - 我认为你需要一个额外的70301A模块来扫描高达18 GHz,或者至少你需要至少支持70301A的固件。
请参阅附件,MMS目录中的页面显示70300A和70301A如何协同工作。 此外,MMS频谱分析仪的主要固件控制是70900A / B LO模块。 请参阅有关70860A固件升级套件的附加信息,该套件显示哪个固件版本支持哪个模块。 首先在B.01.00(880901)固件中支持70301A。 所以,也许您需要确保您的LO模块至少具有此固件版本。希望这有助于 - 70860a.pdf481.7 KB 以上来自于谷歌翻译 以下为原文 Hi - I think you need an additional 70301A module to sweep up to 18 GHz, or at least you need firmware that at least supports 70301A. Please find attached, the page from the MMS catalog showing how the 70300A and 70301A work together. Also, the main firmware control of the MMS spectrum analyzer is the 70900A/B LO module. Please see attached information about the 70860A firmware upgrade kit which shows which revision of firmware supported which module. The 70301A was first supported in B.01.00 (880901) firmware. So, perhaps you need to make sure your LO module has at least this revision of firmware. Hope this helps - 附件
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 08:58 , Processed in 0.709682 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1600
